how to rewire everything
Old Oct 31, 2011 | 08:41 PM
400inatruck's Avatar
400inatruck
I got a 77 f150 that has parking lights, head lights, and tail lights. But no brake lights, turn signals front or rear, and 1 back up light. How do I rewire all of it without messing with the wiring harness? I am thinking about a custom switch panel with each wire wired to the panel, then a ground and a power wire for all.
Old Oct 31, 2011 | 09:09 PM
mark a.'s Avatar
mark a.
Why not just fix it ? The wiring is pretty simple in these old trucks. Sounds like you need a new turn signal switch and maybe a new back up light socket.
HIO Silver's Avatar
HIO Silver
Why not do some troubleshooting instead of bypassing it? I mean, it could be less troublesome and less work than your attempt to rewire it.
<A HREF=http://i55.tinypic.com/21jw50l.jpg>74-78 Wiring Diagram Pt1</A>
<A HREF=http://i52.tinypic.com/35luc8n.jpg>74-78 Wiring Diagram Pt2</A>
Old Oct 31, 2011 | 09:15 PM
79FordBlake's Avatar
79FordBlake
I've had all those problems before and it wasn't the wiring......the sockets were bad.
Old Oct 31, 2011 | 09:25 PM
ctubutis's Avatar
ctubutis
Why don't you fix the problems rather than creating a bunch of work for yourself, the end result of which
  1. Likely isn't gonna do what you need it to;
  2. Would only questionably be street legal; and,
  3. I'd venture to guess that nobody would want to buy this truck from you when you're finished with it.
Incorrectly or poorly-installed trailer lighting kits can cause problems, as can a failed turn signal switch.
Old Oct 31, 2011 | 09:35 PM
JB78f150's Avatar
JB78f150
I wouldn't want to rewire it. Try to see if you can get it back to factory because it will be a lot easier. The wiring in these are pretty easy so it can't be to hard to trace down.
Old Nov 1, 2011 | 08:31 PM
400inatruck
Has any of yall looked at a wiring diagram? they are like 15 pages each. I don't like reading. And for street legality, I live in Alabama, not much illegal. I have checked the back up sockets, everything good. I was thinking it may be the Turn signal switch or the 4 way plug I hooked up. If I could get wiring cab back, I would rewire all the lights cab back and rule out any of it. I got the wire and the diagrams, but probably not enough patience.
Old Nov 1, 2011 | 09:33 PM
Scifi266's Avatar
Scifi266
listen, no one is trying to mess you up here. these a simple diagrams and believe me, a ground could easily cause the problem. I'm all for rewiring when the wires have gotten pretty seasoned after the years but if you do it wrong you're just asking for the cab to catch on fire. done it once, wasn't pretty.
Old Nov 2, 2011 | 09:32 PM
400inatruck
where did I say I was sad? I didn't the last time I checked. Sad response? not really... sad question? nope, not at all. I aint sad, cause there's no reason for me to be. I can rewire the whole set up and prove yall wrong, but if I was missing one thing to check for, I might as well ask. and for everyone whom is actually helping instead of wasting my time, the Neutral safety switch is absent on my truck, not there, and I had back up lights without it. And no, I didn't remove it. The previous owner's father-in-law did. Not sure why.
Old Nov 2, 2011 | 10:03 PM
Carlene's Avatar
Carlene
Admom
Thread closed until a Forum Mod can deal with it.
Old Nov 3, 2011 | 06:11 AM
monsterbaby's Avatar
monsterbaby
Ok I will reopen this thread, don't make me clean it up again.
If you want advice fine, if not don't reply.
And no personal attacks by anyone will be tolerated.
Old Nov 3, 2011 | 07:02 AM
400inatruck
@ Monster baby, is your pic a gremlin from the movie "gremlins"? and how do yall get the capability to close, open, clean, edit, etc a thread?
Old Nov 3, 2011 | 10:05 AM
Sleepy445FE's Avatar
Sleepy445FE
It's that little title of "Super Moderator" under his handle that puts him in charge.
The only thing I've rewired on mine is from the cab back because the wires were left pretty much exposed and had worn through and such. This is what I used Mr. Tailight
Old Nov 3, 2011 | 02:43 PM
LxMan1's Avatar
LxMan1
That's what we (the moderators) are here to do.
Old Nov 3, 2011 | 02:46 PM
monsterbaby
No my picture is Yoda from star wars. or more accurately partying yoda.
