piston ring orientation
Old Oct 31, 2011 | 07:08 PM
76250_4x4's Avatar
76250_4x4
ready to put in my pistons, just looking for the correct way to space the ring gaps. anyone have a diagram? 95 351 w thanks
Old Oct 31, 2011 | 07:11 PM
cj06's Avatar
cj06
12 o clock , 4 o clock , 8 o clock
Old Oct 31, 2011 | 07:15 PM
76250_4x4's Avatar
76250_4x4
12 o clock being the top ring? how should the oil rings be set up? and yes i know the two top rings are compression, there are two oil rings. thank you!
Old Oct 31, 2011 | 07:37 PM
White 97 xlt's Avatar
White 97 xlt
Are you re-using the old rings??
Old Oct 31, 2011 | 07:42 PM
cj06's Avatar
cj06
2 oil rings ? are you talking about a 2 piece oil ring ? if so then just set the gaps 180 deg. apart ! all the rings will move around while the engine is running ! the reason to offset the gaps is to help with initial blow by !
Old Oct 31, 2011 | 08:08 PM
76250_4x4's Avatar
76250_4x4
yes two piece oil ring. and yes im using new rings. thanks
Old Oct 31, 2011 | 10:02 PM
Midnite1987's Avatar
Midnite1987
There should be a chamfer on one edge of the rings as well I believe. From what I fermenter the chamfer faces the top of the piston so that the conbustion gas gets in behind it and firces it out to create a better seal.
Someone correct me if I'm wrong
Old Oct 31, 2011 | 10:34 PM
White 97 xlt
Unless the rings are REALLY cheap there SHOULD be instructions on the package...
krustiy lusti
Dec 31, 2016 12:17 PM
BURNSF250
28
Mar 29, 2012 09:10 PM
Royson12
20
Apr 17, 2011 09:45 AM
64F-100
Jan 14, 2009 01:17 PM
Darkstar
Dec 4, 2002 08:02 AM
