E40D shifting ungodly hard
Old Nov 1, 2011 | 04:23 PM
srsparky32's Avatar
srsparky32
seems like the F-150 will be just fine. it appears to have been a poor or dirty electrical connection to the transmission.
Old Nov 2, 2011 | 11:41 AM
Superduty.pride's Avatar
Superduty.pride
Glad
I'm glad I could lend some help, get that TPS changed, $25 or so and just requires removing the throttle body, the TPS is on the underside, and once you get the new one in place you likely need to check the voltage at closed/partial/full throttle position, I believe it should range from 1V-5Vs I believe. Check the specific voltages for sure online. Good Luck.
Old Nov 3, 2011 | 11:52 PM
srsparky32's Avatar
srsparky32
wasnt the TPS, turned out to be a bad VSS. got that replaced. cant feel the truck shift at all now
Old Nov 4, 2011 | 12:18 AM
Superduty.pride
Ah, well still good results. :P
So that'd be the rear diff speed sensor then? Did you notice any other changes with replacing that?
Old Nov 4, 2011 | 01:00 AM
86F150302's Avatar
86F150302
Did you get a code telling you it was the RABS(VSS)?
Glad you got it fixed.
Old Nov 4, 2011 | 02:40 AM
srsparky32's Avatar
srsparky32
exactly. and nothing other than a very VERY smooth transmission shift. and shifting into gears using the column shifter is way smoother now.
no code, just airbag code which i knew was broken. so i just took a guess on the VSS and what do you know.
Old Nov 4, 2011 | 10:57 AM
ryito1122334455's Avatar
ryito1122334455
told you it was the vss lol
Old Nov 4, 2011 | 05:40 PM
Bankrupter's Avatar
Bankrupter
LOL poor guy was getting lets play guess a part left and right. Gotta love an E40D for telling you a sensor is gone before the CEL. Always pull the codes when the trans goes into that shift pattern. It can be one of any of the sensors these guys suggested. Some times it can be water that got into a connector to any of these also. At least the trans protects itself from slipping !
Old Jun 19, 2012 | 12:17 PM
best4less's Avatar
best4less
hard **** from park to reverse
hello, i just built my trans. and now i have a hard shift when put on reverse? any ideas? no codes and drives great no hard shift at all just when put in reverse ?
Old Apr 27, 2016 | 07:05 PM
quicksilver4460's Avatar
quicksilver4460
E470D Hard Shift
I have a hardshift problem with my E40D, 1992 with 50k miles. Just did a flush and BG added. The fluid was a mahogany color. Took it to Mr transmission, and said it had a ton of codes in it, so the last code was the MAFM Sensor. I replaced that and the sensor in the middle of the 7.5l engine. It seemed to work, but when it gets hot it still shifts hard. When it is cold, it is fine. They cleaned out the valve bodies, and I replaced the solenoid pack. Still clunks. It seems when the RPMS are higher, it clunks less. Any idea on what causes this?
Old Apr 27, 2016 | 07:14 PM
Lead Head's Avatar
Lead Head
What's the MAFM sensor? Do you mean MLPS?
Old Apr 27, 2016 | 07:52 PM
quicksilver4460
Mass Airflow meter, on the pass side of the firewall
Old Apr 27, 2016 | 09:28 PM
  #28
Lead Head's Avatar
Lead Head
There is no mass air flow meter on your truck. That is the manifold pressure sensor.
You should pull the codes yourself, and see what's actually wrong.
Old Nov 1, 2016 | 06:58 PM
  #29
Travis Gardner's Avatar
Travis Gardner
Hard shifting from 2-3
1999 f250 superduty 7.3 Shifting hard from 2-3 replaced the VSS did seem to help a little but still shifting hard. Especially if I'm in the throttle! What next?
Old Nov 1, 2016 | 07:53 PM
  #30
Lead Head's Avatar
Lead Head
I'd probably start by making a new thread in the correct (SuperDuty) section. This is a thread about a different transmission in a different truck with a different engine.
