Am I missing something ? I don't see where the starter was pulled and tested, or anyone suggesting it. Starters go bad, sometimes in peculiar ways. What you're describing is typical of a starter with a bad stator. When you've been driving, then you park and shut the engine off, underhood temperatures skyrocket causing a condition called Heat Soak ( Chevy guys with the starter mounted solenoids know allll about this ) The plates that make up the stator in your starter swell and bind causing massive amounts of internal drag....that's why when you shut it off for just a few seconds it rolls right back over, but give it ten minutes and it slugs. If you have the little reduction gear starter with the second solenoid mounted on the starter, you get even more voltage loss due to carbon buildup from the arcing of the solenoid contacts.
IMHO....the reduction gear starters with the second solenoid should be thrown away...They're less reliable than the Pole Shoe starters, generally have plastic planetary gears, and make it overly complex, placing a constant 12v+ cable right next to the hot exhaust. Who has a stock engine that has *so* much compression a standard starter won't turn it over ??? Just my .02 cents.
-Scott
Pretty good advice.....the starter might also be loose....I'd swap out the ground cable also......mine was doing something similar.....the starter bolts had backed out
Did they do a load test on the battery or just check voltage. The gauge in mine reads 16 volts when its running, but when i check it with a volt meter its only just over 14 so i dont put a lot of faith in the dash gauge.
That's a good question. I was standing there while he had his testing device connected and he just told me that the the alternator was good while the engine was running. I didn't think to ask if the device did a load test or not.
I agree that it's bad to put faith in the apparent voltage reported by the dash guage, but I do think it's ok to note that it is in the "usual spot". Except now it seems to stay at the usual high mark no matter what RPM the engine is running at whereas before it would seem to wane a little at low RPMs.
-Scott
A few months ago I had a different problem [that I still have intermittently] and I did take the starter off and have it tested - and it tested good. Doesn't mean it's still good today so it's worth a shot to retest. Thanks.
RE: "the different problem"... it seems like a weather change triggers this... but sometimes when you turn the key you hear the thump of the solenoid kicking in but no turning movement is attempted. Keep trying and sometimes after say 50-100 reattempts it will turn over and start as if it never had a problem. Then it will go weeks without re-appearing.
A few months ago i did remove the starter to get it tested so it's possible I did a poor job of tightening it when I put it back. Yes, may as well replace the ground cale too at this point. Thanks for the advice.
Have you replaced the starter solenoid ? ....it's a battery cable I think.....these things are known for that being an issue....if it was bad it can take out the starter....they are both cheap.......replace them both .......also check all the connectors under the master cylinder on the fender well for corrosion.....mine were eat up.....had to hard wire around them.....all kinds of crazy problems there that were weather related
With the key off and the hood down low enough that the little hood light isn't on, should any power be bleeding off the battery? I tried this with the starter removed so the positive side of the battery was only connected to the solenoid on the firewall.
If I put a voltmeter across the battery terminals with the positive cable disconnected the voltage is steady. If I connect the positive cable (negative cable is still attached) I see the voltage on the meter start to go down.
I know that some components are always hot like rear window, power door locks, lights, cigarette lighter, ignition switch but I shouldn't expect anything to draw any current. Right? Could the ignition switch be faulty?
I put a test light between the positive post and the positive cable and started pulling fuses from the inside cabin fuse box and then the under the firewall fusebox. Light stopped glowing when I pulled the fuse from position 1 of the box under the hood.
According to an online manual it appears the the 20A fuse in position 1 is for the audio system. Interesting. I didn't think it was hot all the time since the radio turns off when the key is off. [Unless the key isn't really turning things completely off anymore - it has gotten pretty loosie goosie in there.]
Or is Audio referring to the bell that chimes when the key is in the ignition with the engine off?
I had a similar problem on my 90 the key was not shutting the radio off and the battery would die. I thought at first it was the way the aftermarket stereo was installed but after replacing the ing switch it stopped. Replacing the switch is pretty easy
Well it starts now. Turns out the battery WAS bad. I ended up replacing the negative and positive battery cables. Guess it either went bad over the course of the week or the 1st AutoZone needs to recalibrate it's battery tester.
The Duralast battery was just over 3 years old so I missed the 100% replacement by a few weeks. I did get $40+ back on the prorate though.
Thanks Pat. I think I'll do that pretty soon. The key falls out of the ignition as I'm driving down the road sometimes.
I also so a thread on here about adjusting the linkage so the truck knows when it's in park that I need to pursue.
ok, i have a 78 ford Bronco 4x4, 351M with a C6 Tran, 205 transfer. when i got the bronco @ 3-4 months ago, it had a push button starter on the dash. I don't like things Jerry rigged, so i thought that someone was being lazy and dident want to spend the time/money for a new ignition switch. I bought a new one (12$) took the old one out and put the new one in, turned the key and it did nothing. Next i thought, ok its the solenoid, so i bought a new one and put it in. I put the wires back on the solenoid, minus the push button wires and turned the key (one) click, and the starter started turning! i have tried every combination (moving the wires around) ans still nothing. i need help please. i am stumped.
I would try that but the only wiring is from the top. And there are no wires at the bottom I just rebuilt the hole column. Are you saying it needs to be hooked up to compleat some circuit?
