Fuel rail Question
Old Oct 31, 2011 | 04:08 PM
quisp's Avatar
quisp
Fuel rail Question
1988 F150 5.0 EFIBeen having some problems with my fuel system,I know its a batch of bad gas- smelled the plugs, -varnish smell.I changed the plugs out with some new ones,But the Truck still wont fire over, seems to catch, but wont, It just turns.I'm hoping I dont have gummed up Injectors from the Bad Gas, and Im ready to take out the injectors, and clean them,SO..I cranked the motor to see if it would start,- Nope.I didnt bother relieving the Fuel pressure by means of the switch under the dash, and decided to depress the Schrader Valve on the Fuel Rail instead.I used a small screw driver, and slowly pushed down on the valve-Nothing but Air came out- No Fuel whatsoever...low pressure too.I was expecting Fuel. Is this an Indication of something like a bad fuel pressure regulator??Anyone familiar with early Fuel systems ? Need a point in the right direction.Thanks.
Old Oct 31, 2011 | 10:37 PM
Conanski's Avatar
Conanski
Your truck has a complicated fuel sytem on it with low pressure pumps in each tank, a high pressure pump on the frame, and a tank selector valve and seperate filter also on the frame, and a problem with any of these will cause low fuel pressure.
Old Nov 1, 2011 | 08:02 AM
drs1023's Avatar
drs1023
Similar issue on my '87 F-150 a few months ago. It was the frame mounted pump.
bmxerbrett
21
May 15, 2016 03:04 PM
jr2000sd
Aug 14, 2014 06:16 PM
88 250
Oct 5, 2010 12:37 PM
Crazz
Jul 24, 2004 10:09 PM
vee-eight-fords
Jun 7, 2004 09:22 PM
