Sponsored by: Auxito
Compression Test with intake manifold removed
Old Oct 31, 2011 | 12:26 PM
Lennyg's Avatar
Lennyg
Question Compression Test with intake manifold removed
I know I should have done a compression test first.
But in my attempt to locate the cause of coolant loss I have removed the intake manifold.
I don't really want to remove the heads unless I know the gaskets are leaking.
My idea is to modify a simple compression tester so that I can thread a fitting into a spark plug hole, put a tee on that fitting, connect a pressure guage with air release button to one port on the tee and a compressor fitting on the other port. Then I can pressurize the cylinder, disconnect the compressor, and see how fast it loses pressure. I'd have to plug the fuel injector hole and manually rotate the engine so both valves are closed.
Is this possible? Has anybody ever tried anything like this before?
Old Oct 31, 2011 | 03:15 PM
Bluegrass 7's Avatar
Bluegrass 7
What your trying to do is half of a cylinder seal test that would tell you a rough percentage of leak down.
Doing such a test requires you to have a means of locking the crank from rotating because the pressure will attempt to push the piston downward same as combustion would unless you place each piston at exact top dead center for that cylinder under test.
A standard cranking compression pressure test should be good enough to pick out a cylinder down on pressure as compaired to the average of the other 5..
As far as injectors goes, removing the connectors will stop them or removing the cam position sensor connector will stop them.
Other way are removing the PCM fuse, crank sensor connector will stop all actions.
Good luck.
Old Oct 31, 2011 | 04:41 PM
Lennyg's Avatar
Lennyg
So, it might work?
I have already removed the fuel rail with injectors. I guess I could just reinstall the rail with injectors to plug the holes. (this is a 2001, 4.2L on a F-150, XL, 2wd)
I didn't want to crank the engine because with the intake manifold removed - I thought the remaining coolant would be thrown all over the place.
Looking back at my first statement - it would work better to put the guage on one port of the tee and put the one way valve (that comes with the compression tester) between the compressor and the other port of the tee.
Old Oct 31, 2011 | 09:03 PM
steve(ill)'s Avatar
steve(ill)
the coolant leak is internal ? You could also plate over the intake maniifold ports (and water ports), then put pressure on one fitting into the water jacket, then see which cylinder the air leaks out of by putting a thumb over the spark plug hole. If the head is cracked or gasket blown on one cylinder, you would have air leak into that cylinder.
Old Nov 1, 2011 | 12:13 AM
Torky2's Avatar
Torky2
Not sure why, since you are talking about applying compressed air to the cylinder via the spark plug hole... it's not a Diesel, and it is long before the Direct-Injection gas engine. The injector tip does not enter the cylinder.
Another idea is to pull the block drain plugs and empty out all of the antifreeze, so you can crank it with the starter and do a (cold) compression test. But disable the fuel pump circuit first before cranking
Old Nov 1, 2011 | 11:29 AM
Lennyg's Avatar
Lennyg
You found me out. Amatures like myself should probably not be digging this deep into a motor. I think at this point I can get it back to at least the same shape it was before I started. I don't think I would pull the heads myself even if I discovered the head gaskets were bad. Thanks for the input - it has been helpful.
Old Nov 5, 2011 | 09:35 AM
SwOkcOffRoader's Avatar
SwOkcOffRoader
Do not pull the heads. Most Mod motors cannot be reassure properly without a full teardown. I know people who have done it successfully, but I know more people that tried and failed. These motors must be assembled in order so all the covers and pans line up right and seal correctly. Very difficult to do in the truck unless you have built one correctly before.
wallywally
Dec 1, 2023 07:44 AM
good9682
May 25, 2015 07:46 AM
69_Eliminator
Modular V10 (6.8l)
Apr 20, 2015 11:40 AM
8525ford
36
Jul 21, 2010 03:44 PM
704 dentside man
Jul 7, 2010 10:09 AM
