So i scored a sidewinder intake for my 410 the other day.I rember hearing a reading somthing long time ago about 427 intakes dont quite bolt up to the standard fe block.
so whats needed if anything to put my sidewinder on the engine???
It should bolt up just fine. Good luck tuning that thing though, Jay's book showed very wide measured A/F ratio variance from side to side because of the offset design.
For gaskets, stay away from Felpro printoseals. Lots of bad stories. I use Victor MS15166X and haven't had a problem. The Victors are silicone molded over stamped aluminum while the Fel Pro gaskets are silicone molded on paper. I don't ever use the end gaskets. Just a bead of the Right Stuff on the front and back.
sweet,looks like the snow might be melting off, should beable to get it on today then...i got a long tripp back to north dakota, ill have a lot of time to play w/it.
