Sponsored by: Real Truck
pass. side h.i.d wont work
Old Oct 30, 2011 | 05:13 PM
Sickler1's Avatar
Sickler1
I have an 03' f250 I've had Hids in my headlights for about 3 months.my pass side went out so i changed the ballast wit three new hallways and a different bulbs still nothing...
Any ideas on what can be making it not come on?
Old Oct 30, 2011 | 06:15 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
dumb question, but did you change the fuse?
Old Oct 30, 2011 | 06:28 PM
Sickler1's Avatar
Sickler1
Will check fuse...
Old Oct 30, 2011 | 06:44 PM
Sickler1's Avatar
Sickler1
Fuses r good
Old Oct 30, 2011 | 08:06 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
all 4 fuses? 2 for lowbeams, 2 for highbeams
next thing would be to check and see if you are getting voltage. turn on the headlights and use a voltmeter. Check each of the 3 wires on the pigtail. 1 should be power. mark that as lowbeam. switch on the highbeams. the other wire should be powered.
if you aren't getting power, start looking for a ground. most likely it's something to do with your HID's. but you never know
Old Oct 30, 2011 | 08:40 PM
cbzdel's Avatar
cbzdel
first thing, check the wiring with a volt meter, if it has power, swap the bulbs, if the working bulb works in the headlight with the dead light the problem is the bulb. If it does not work and you are 100% its getting power the problem is the ballast.
Old Nov 1, 2011 | 05:57 AM
Sickler1's Avatar
Sickler1
Didn't check it wit a voltage meter yet but put the stock bulb back in an it worked...switch the working driverside setup to the pass side and nothing....
Washbish8762
6.4L Power Stroke Diesel
Sep 14, 2014 10:30 PM
RainHellFromAbove
Sep 9, 2012 04:22 PM
fbh31118
Electrical Systems/Wiring
Sep 15, 2011 05:37 AM
roree
Jul 10, 2008 02:51 PM
Rizon
Sep 24, 2007 09:55 PM
