Help me identify an unplugged cable
Old Oct 30, 2011 | 03:32 PM
apoc192's Avatar
apoc192
Copied from the superduty forum
While switching out both batteries of my 2005 F250 PSD I noticed that there was a cable unplugged in the front right corner of the engine bay. It is fairly small and grey. I could not for the life of me figure out where this little guy goes. I have attached some pictures to make it easier to identify. Thanks in advance for the help guys!
Old Oct 30, 2011 | 04:30 PM
Rusty Axlerod's Avatar
Rusty Axlerod
On my truck (06,CC,Auto) there are two connectors on the bottom of the master cylinder coming up from the bottom. The back one looks like the one you are holding. Wire colors match except my red has white trace while your trace is purple. Also, I noticed on mine there is a blank plug ( for stowing a connector) on the large harness in the same area. May be a connector is not used on certain models would stow there.
Old Oct 30, 2011 | 09:21 PM
zhilton's Avatar
zhilton
Dumb thought, do you have an codes showing? If it was supposed to be plugged into, the PCM would be looking for that sensor. But as Rusty said, the wiring harness is built to cover several different versions of SuperDuties, so it's possible that doesn't apply too your truck.
Old Oct 30, 2011 | 11:51 PM
PowerStrokeHD's Avatar
PowerStrokeHD
The connector is for the brake pressure transducer on vehicles equipped with the factory trailer brake controller. It would plug into the bottom of master cylinder.
Wire Colors - Red/White, White/Red and Tan/Yellow
Old Oct 31, 2011 | 06:24 PM
apoc192's Avatar
apoc192
Brilliant! That must be it because I don't have the factory brake controller. Thanks a bunch guys.
Old Oct 31, 2011 | 09:09 PM
zhilton's Avatar
zhilton
And the reason it didn't click in my mind is the '03/'04 trucks don't have factory brake controllers.
gradyc
Jun 8, 2014 10:10 PM
tettnanger7
All Things Towing
Sep 21, 2009 03:04 PM
AltaEx
May 10, 2008 08:45 PM
bigscrb15
May 30, 2006 12:32 PM
gtslabs
All Things Towing
Nov 5, 2004 03:58 PM
