Valve covers
Old Apr 10, 2003 | 10:44 PM
BS in AZ's Avatar
BS in AZ
Valve covers
I am replacing some crappy auto zone valve covers on my 82 bronco with a set of Hollys. I have a rebuilt 351 W from a 83 bronco in it now. Is this a hard job for a someone who has never done much more than change the oil and preventive maintence stuff like that. Any advice on the easiest way to do this, and some tips that would help me out. Thanks for any input.
Old Apr 11, 2003 | 03:10 AM
macguyver's Avatar
macguyver
Valve covers
Whatever you do, don't use RTV on the valve cover gaskets. It's just too slippery and you risk damaging the gasket or having it slide out of position. Some guys like the rubber gaskets. I'm still sold on the old cork gaskets. I stick them to the valve covers with K&W copper coat spray (light coat on both gasket and valve cover and let it set up. Acts almost like contact cement but will still clean up easily later). Then a light coat of grease on the gasket where it contacts the head to keep it from sticking.
Make sure you remove any trace of the old gaskets and don't over tighten the bolts.
Just my 2¢
Greg
Old Apr 11, 2003 | 08:22 PM
Franklin2's Avatar
Franklin2
Valve covers
I still use silicone on the valve cover side. Or some sort of glue type sealer would work too (whatever you prefer). I agree-don't use any sealer on the head side.
Make sure your valve covers have baffles where the breathers/pcv valves plug in. Or you will burn some oil.
After the install, run it for a couple of days and re-tighten the bolts with a nut driver or with one hand on the head of the ratchet. Over tightening bends the valve covers. After about a week re-tighten again and you should be good to go for awhile.
4x4man514
Sep 20, 2015 10:57 PM
sprtkr1
Apr 5, 2007 08:00 PM
Ben242
1978 - 1996 Big Bronco
Mar 6, 2004 12:11 AM
gt bronco
Dec 8, 2002 06:35 PM
CRJ900
13
Dec 20, 2001 01:14 AM
