High Efi valve covers
Old Sep 14, 2015 | 11:48 PM
4x4man514's Avatar
4x4man514
Can anyone point me to some valve covers that will clear roller rockers and are still set up for efi? I already have a 1 inch spacer between the upper and lower to alleviate some of the problem. I have bronco script valve covers now that clear fine but the oil filler neck is in the wrong place.
Thanks guys maybe on of y'all can straighten me out!
Old Sep 15, 2015 | 06:48 PM
jimbbski's Avatar
jimbbski
What brand of roller rockers.
Ford used Crane made rockers on the Cobra engines and they used plain old stamped steel valve covers. The cast aluminum covers used on standard HO 5.0's can be made to fit with a minor mod to the inside of the cover.
Old Sep 15, 2015 | 08:38 PM
4x4man514's Avatar
4x4man514
I just pulled the trigger on some ford racing m6000 j302r. They look like the efi valve covers but are supposed to be taller . I hope they work. I'm running crower full rollers I can't remember the ratio. Any experience with these covers?
Old Sep 16, 2015 | 05:37 AM
jimbbski's Avatar
jimbbski
Your using racing like parts so I can see why "normal" valve covers don't fit.
No I don't have any experience with those parts. But I would think that any "tall" style cover should work fine.
Old Sep 20, 2015 | 10:57 PM
baddad457's Avatar
baddad457
I'm running a set of 1.7 Cobra roller rockers under the stock covers on my 96 E150's 351 with no contact. It's not the height of the covers, but the oil baffle inside that makes contact.
TexasGuy001
May 21, 2018 10:11 AM
jerg_064
Mar 3, 2008 08:45 AM
Jrock909
Mar 4, 2007 09:22 AM
bronco-bud
Sep 7, 2003 12:35 PM
restorit
May 29, 2002 11:32 PM
