Hydrogen kits?
Old Oct 30, 2011 | 12:43 PM
Trevor.801's Avatar
Trevor.801
Hydrogen kits?
Anybody ever used one of these? I am reading an ad for a local company that professionally installs these kits and is talking about mileage increase. Just wondering if anyone has actually used one. Thanks for any input.
Trevor
Old Oct 30, 2011 | 12:59 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
here we go again
search for "brown water" or "HHO" or "perpetual motion"
it's all a crock of crap. Save your money, and most importantly, don't install this crap on your truck. You are more likely to blow your motor up or cause other serious damage.
These kits work by fooling the PCM and adding unmetered air after the MAF. The MAF doesn't see this air, so the A/F mix gets leaned out. A more lean mix burns hotter and is more efficient...to a point. To much though and you will burn a hole in a cylinder.
You would be better off doing a Oil change, fuel filter, air filter, spark plugs, rotate tires and check the pressures. You know, the basic tune up
Rag1996
1983 - 2012 Ranger & B-Series
Nov 16, 2007 04:31 PM
chevy_man2454
1997 - 2003 F150
18
Aug 29, 2007 11:30 AM
ken1mod
Aerostar
13
Nov 24, 2006 01:40 PM
SB-Razorback
Modular V10 (6.8l)
Mar 14, 2004 12:29 AM
firenut
May 7, 2001 11:57 AM
