Block heater working?
Old Oct 30, 2011 | 11:52 AM
jayc3169's Avatar
jayc3169
How do I know if my block heater has malfunctioned? Is there a way to diagnose it. I ask because my truck does start like it used to when plugged in. She starts like she hasn't been plugged in all night.
Old Oct 30, 2011 | 01:58 PM
mhoefer's Avatar
mhoefer
Check the cord for burns or chaffing. Does the cord have resistance, it should rad the same as an extension cord in ohms, also try unplugging from block and measuring across the poles for the heater. If it's infinite, it's toast. Ussually they will just trip the breaker so check those as well.
Old Oct 30, 2011 | 05:39 PM
cheezit's Avatar
cheezit
check the water tempature in the degas bottle.
Old Oct 30, 2011 | 06:57 PM
Piolet's Avatar
Piolet
Plug a light into a power strip. Turn it on and leave it on. Plug in the block heater into the same strip and see if the bulb dims.
Old Oct 30, 2011 | 09:13 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
If you have a home depot by you, you could buy a kill a watt meter for $25.00 it shows amperage voltage watts & a lot of other readings. Good device to check the real load of block heater.
Old Oct 31, 2011 | 12:41 PM
Cowboy65's Avatar
Cowboy65
If you are able to monitor the current it should be 8-10 amps.
With the heater unplugged check for shorts to ground and also check the heater resistance. The resistance should be around 15 ohms.
Old Nov 1, 2011 | 12:08 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
The block heater pulls about 1,100 - 1,200 watts of power (have no idea what that is in Ohms or any other measurement).
Youe lower radiator hose should be warm due to the coolant being heated up. The lower radiator hose will warm up before you will be abel to notice the upper radiator hose (untill it gets real cold outside).
Here is a link to an old thread I was part of regarding adding an extention to your block heater and making plugging in easier (pics included in my post within the thread below).
https://www.ford-trucks.com/forums/1...ml#post9701337
Old Nov 1, 2011 | 01:26 PM
BLADE35's Avatar
BLADE35
Its getting into the 30s here at night and I still havent pluged in yet
Truck starts Good I do run synthetic oil and the FICM volts 48-49v
If its stuggling now it will really have a hard time when it gets Nasty Cold
If I was in your shoes Id be checking the FICM Voltage
Get a scangauge or something that way you could check the FICM Volts and you could also look at ECT to know if the block heater is working properly
Sean had some notes that he took last winter on temps/time the block heater had been plugged in Hopefulley he will see this and post them for you
Old Nov 1, 2011 | 06:48 PM
jayc3169's Avatar
jayc3169
I've checked the voltage. Its good. I'm getting a P0630 code on cold start ups though.
Old Nov 1, 2011 | 08:09 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
By the way, just for info. I did this test last winter, just thought I would throw this in here.
This morning I plugged the block heater in. My Scangauge read 39 degrees.
1 hour later it was 80 degrees.
2 hours later was 94 degrees.
3 hours later it was 103 degrees.
4 hours later it was 110 degrees.
5 hours later it was 116 degrees.
Yes, 39 isn't that cold to start, but was interesting to see that it went from 39 to 80 in an hour.
Currently my oil temp in hour 3 is 77 degrees. It was 40 at starting point.
Oil temp after 4 hours is 91 degrees.
Old Nov 1, 2011 | 08:12 PM
BLADE35's Avatar
BLADE35
Thanks a Bunch Sean This will Help
Old Nov 1, 2011 | 08:16 PM
BLADE35's Avatar
BLADE35
check that code again I cant find that specific code for Diesel truck
Old Nov 1, 2011 | 08:37 PM
amdriven2liv
Here is what I found on that code:
P0630 VIN Not Programmed or Incompatible - ECM/PCM
http://www.dieseltalk.com/support/DTC.pdf
Beachbumcook
Got Diesel?
I don't plug in unless really really cold (ambient temps in the teens or below - usually 10 or below would be normal for me)... and that is just so I can do it and "look cool" to my buddies.
With Powerservice anti-gel in the fuel (every fill-up and I prefer to double-dose) and synthetic 5W-40 in the crankcase... plugging in isn't even really necessary, but it does help of course.
Homerunking2394
Nov 29, 2018 09:09 PM
rocket_scientist
Dec 30, 2017 04:25 PM
going360
32
Dec 30, 2007 07:43 PM
Byrddog
Jan 3, 2006 07:24 PM
MilesTeg
Jan 11, 2004 02:19 AM
