Stuck on pullaway
Old Oct 30, 2011 | 11:15 AM
valdor's Avatar
valdor
Stuck on pullaway
Hi there, im really hoping i can get some help here. I have a '72 F250 4x4 with a 351 Cleveland and C6 tranny. (The transfer box is a Dana 24). So i am lately having trouble getting moving when i fire her up. Start her up in park, let the motor idle and settle, let the handbrake down shift to reverse or drive and then she is just not willing to go anywhere without some happy pedal encouragement. After a while she will "free up" and happily trot along. Also im getting a horrible (i think?) 5 mpg. Mebe if the drag free up it will increase. Anytips/possible diagnoses?
Kindest regards,
Valdor
Old Oct 30, 2011 | 11:17 AM
beartracks's Avatar
beartracks
Could be the choke stuck or misadjusted. Your engine should not be a 351C.
Old Oct 30, 2011 | 01:15 PM
valdor's Avatar
valdor
Hi thank you for reply. Any reason why it shouldnt be a 351C ?(Cleaveland)
Old Oct 30, 2011 | 10:53 PM
ctubutis's Avatar
ctubutis
Beartracks,
I know Ford installed the 351C in Australian trucks, I'd have to guess they did the same in South Africa where this guy is, too.
Valdor - you're basically saying the truck won't move in forward or reverse unless 1) you step on the gas, or 2) the truck warms up, correct?
Looking at #1, a cold engine/transmission... you move the gear shift from Park to Reverse or Drive, do the engine RPMs drop and can you feel the transmission going into gear?
Check your ATF level, tranny needs to be warm to do it....
Old Oct 31, 2011 | 10:28 AM
mark a.'s Avatar
mark a.
Parking brake cable froze up ?
Old Oct 31, 2011 | 01:55 PM
valdor's Avatar
valdor
Originally Posted by ctubutis
Beartracks,
Dear sir,
thank you for your reply, and yes to both your questions, i can clearly feel she goes into gear and the revvs do drop when goin from park to drive or reverse. Mark a. has said something that interists me. will ask below his comment.
Oh BTW, as far as i can tell by almost without exception Ford South Africa has installed the 300 i6 in all F-series (F100,250,350) with the exception of a 4.1 L Perkins diesel i6. The Cleveland V8 is almost certainly an afetrmarket convertion. I have the truck for about 5 month and 'cept the horrible 5mpg i LOVE IT!!!
Kindest regards,
Valdor
Old Oct 31, 2011 | 02:00 PM
valdor's Avatar
valdor
Dear Mark a,
I am absolutely no mechanic but what you suggest makes so much sense (to the layman in me atleast). The truck feels like the handbrake is applied or im stepping on the brake pedal trying to pull away. Later it loosens up though.. Til i switch off and pull away agen that is... Does this make any sense regarding your "innititial prognosis" ?
Thank you for your reply.
-Valdor
Old Nov 1, 2011 | 10:39 PM
crsmiffy's Avatar
crsmiffy
That sounds fair about the handbrake, but I don't know about it freeing up. Maybe you just have more momentum. I'd look at that real quick as it will destroy the drum/rotor pretty quick if it is that.
Old Nov 2, 2011 | 09:10 AM
valdor's Avatar
valdor
Dear crsmiffy.
Have been checcking out the brakes and it is not that as it easily spins around. Beartracks mentioned somrthing about the chike . At first thought he may have misunderstood me but after chatting to someone it seems this may indeed be the case.... Or possibillity atleast.
Thank you for you reply, all advice is welcome and investigated.
Valdor
Old Nov 2, 2011 | 10:44 AM
80broncoman's Avatar
80broncoman
try this next time you start it up and its dead cold get it in gear and drive it for a 1/4 mile then get out and see if any of the 4 brakes are Hot.
If so then you have most likely found the problem.
Old Nov 2, 2011 | 03:32 PM
crsmiffy's Avatar
crsmiffy
rip the air cleaner off and look down the top of the carby when the engine is warm and see what the position of the choke flap/butterfly is.
Old Nov 8, 2011 | 09:19 AM
beartracks's Avatar
beartracks
You can check the choke by removing the aircleaner. Hold the throttle open slightly (engine off) and push on the choke plate. On a cool morning it should just close by itself. Then after it warms up you need to be sure it opens all the way.
Old Nov 11, 2011 | 06:27 AM
valdor's Avatar
valdor
Hi there, so sorry for not replying to you all who try helping me out. Was away (That damm activitty called work...).
I took the aircleaner off while idling and the choke plate was in uprite possition.. Is this open ?
Old Nov 11, 2011 | 07:45 AM
crsmiffy's Avatar
crsmiffy
If it is upright it shouldn't be blocking off the airflow. If you can look down into the carb that's open
Old Nov 11, 2011 | 03:49 PM
beartracks's Avatar
beartracks
Another possibility is that your float inlet valve in your carb is sticking and forcing extra fuel into the engine.
Also, if you have vacuum advance on your distributor it could have failed and left you with too little spark advanc.
