Sponsored by: Kumho
Smaller Tires for towing
Old Apr 10, 2003 | 09:15 PM
samven's Avatar
samven
I was just wondering about putting a smaller profile tire on my 95 F150 for towing. I have the 5.0l with 3.55 rear and 5speed manual trany. I want to tow a small TT that will weight in about 2700 lbs when loaded and rather than change the rear to 3.73 for more pulling power I thought this might accoplish the same thing. Any downside you know of and what tire could I use. I currently have the stock P235 75 R15 on it.
Thanks,
Sam
Old Apr 10, 2003 | 09:29 PM
MustangGT221's Avatar
MustangGT221
I don't think you're going to get that much power out of it for it to be worth it. I go from 235s to 32's and it doesn't make that much of a difference in my opinion.
Old Apr 11, 2003 | 08:31 AM
superrangerman2002's Avatar
superrangerman2002
Stay with the 235's.
no to mention that the weight capacity of each tire drops of significantly below 235/75/15's (I'm talking load range ratings).
There won't be much of a noticeable advantage to going with a smaller tire than you currently have. The only thing that you'll probably notice is a lighter wallet.
Now if you had 35's on that rig it would be a different story...
Old Apr 25, 2003 | 10:50 AM
ClydeSDale's Avatar
ClydeSDale
Here's a link where you can play with tire sizes, axle ratios, etc.
http://www.differentials.com/producti.html
I run 245/75-16's at present but was playing with going to 235/85's to highway cruise at a given speed at a lower rpm, something more in the torque range for my 460 w/o changing axle ratios. It will at least give you an idea of how much things could change.
Have fun with it.
DSXMachina
Feb 4, 2017 11:03 AM
xtrm1stang
All Things Towing
Mar 9, 2016 07:07 AM
gcorse
Mar 12, 2013 05:13 AM
newfieboy
2009 - 2014 F150
Mar 22, 2010 05:17 PM
calazo
1978 - 1996 Big Bronco
Feb 16, 2009 01:38 AM
