1978 - 1996 Big Bronco
Help: Tire swap predicament
Old Feb 13, 2009 | 03:38 PM
calazo's Avatar
calazo
Exclamation Help: Tire swap predicament
Hi Guys,
My 2nd Bronco (1994 XLT, Stock 302, E4OD, 3.08 gears) came with LT31x10.5 R15 tires (which are manufacturer recommended, I believe) which are too tall for my garage (and I have less visibility than in my 1st Bronco with smaller tires) and the ride is rather stiff compared to what I used to have in my first Bronco, P235-75-R15 tires, which worked well in most areas, except maybe in the looks part. I want to swap the 31" tires for the 235-75... again. I also believe I will gain (with the smaller tire) in torque, city fuel economy and acceleration, plus I need a softer ride for my 5-month old baby who rides in the back next to my wife (now a Bronco-lover too..), what do you think? is it worth the change according to what I need?, thanks.... Uh, before I forget, I don't do much off-roading, no towing and only moderate hauling.
Thanks!
Old Feb 13, 2009 | 07:05 PM
Conanski's Avatar
Conanski
Yes.. P series tires have a 2 ply sidewall while LT tires have 4-ply sidewalls, so ride will be smoother. If your truck has quad front shocks remove 1 pair for more ride improvement. 3.08 gears suck.. should be 3.73 or better with the 5.0.
Old Feb 13, 2009 | 09:17 PM
helirich's Avatar
helirich
Everything is correct except that you will get worse fuel millage with shorter tires, not better. Taller tires give you better millage except when they get so tall that you cant use overdrive.
Old Feb 14, 2009 | 05:02 AM
b4hntn's Avatar
b4hntn
You might want to check the height difference between the two sizes then divide by 2 to estimate how much the axles will lower to fit your garage.
Mine origanally had LT31x10.5 R15 from factory. I recalibrated the speedometer because I am now running P235-75-R15 Uniroyals. There is some whipping when trailer towing. Raising rear psi to 38 helps. Next tires will be P235-75-R15 Long Trail...Tour (Uniroyal or Bridgestone, can't remember but same company anyway). Dealer gets no complaints on the new Tour tire that handles water better than the Long Trail. Says we can inflate to 51 psi when needed on them then be sure to lower the pressure to normal when not needed. He does not recommend more than 38 on current tires. I seldom get off road deep into the woods except to pull son-in-law's tractor out of the mud or sand. He burries it about once a year and his Z71 is usually not adequate.
Old Feb 14, 2009 | 10:47 AM
Cdy1's Avatar
Cdy1
i have a 95 with P265/75R15 uniroyal cross countrys i do some towing, its does great there big but not too big, theyre biggest recomended by ford, and they dont look to small for the truck like the 235's
Old Feb 16, 2009 | 01:38 AM
greystreak92's Avatar
greystreak92
Where'd you find a 94 with 3.08's? I know it was available but I didn't know... well anyhow, Your rpm's are gonna climb just a bit with the shorter tires which COULD contribute to poorer mileage. It really depends on your driving style and the terrain. Hills are gonna hurt (unless you "run 'em"... truckers trick and only slightly illegal).
dpbrowne
Mar 13, 2005 09:42 AM
caddywhompus
Jan 11, 2004 02:47 PM
yoda
Oct 12, 2003 08:38 PM
Bonifacio
Jul 18, 2003 02:28 PM
SAR Ranger
May 23, 2003 01:27 AM
