77 - 79 C4 ?
Old Oct 29, 2011 | 10:14 AM
old rat's Avatar
old rat
77 - 79 C4 ?
Need to replace 77 C4. Found good deal on a 79. Direct Replacement ?
Old Oct 29, 2011 | 10:23 AM
kingford72's Avatar
kingford72
there are two different c4's, 1 - has a big bell housing, 168 tooth flywheel, and a dipstick in the side of the pan. 2 - has a small bell housing, 157 tooth flywheel, and a dipstick that goes into the case. By big and small, I mean the bolt pattern that bolts to the trans side of the bell housing the engine side is still the same. there are differences in the older trans (68-69). Both can be used if you have all the parts listed above. just a note I've only seen the large style in the trucks, so maybe the small type was a car thing.
Old Oct 29, 2011 | 02:38 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
I'd rebuild what you have, then you know it's good. If you can remove and replace it yourself it saves a bundle.
veedogtoo
Aug 11, 2012 07:22 PM
johnb3006
Mar 28, 2011 06:07 PM
WV794x4
Jan 8, 2011 12:16 AM
67ranchero
Aug 12, 2004 07:26 PM
robduval
Apr 9, 2004 08:56 AM
