c4 questions
Old Jan 30, 2011 | 12:04 PM
johnb3006's Avatar
johnb3006
c4 questions
are there different c4 tranny's? I have a 77 150 with a c4 and pulled what I thought to be a c4 from a 80 model car. each has 11 pan bolts, removable bell housings, pumps and shafts appear to be the same. my bell housing bolts up differently though. mine bolts to the case, the one from the car bolts to the pump. only differnece I have noticed other than bell housing is that the dip stick tube on mine is in the pan, the tranny from the car has the dipstick in the housing. are there adapters that will make these interchange? any info would be great.
Old Jan 30, 2011 | 01:34 PM
finneys98xj's Avatar
finneys98xj
Are you sure the bell housing is the one you need? It should bolt right to your motor and in your truck. The tail shafts may be a different lenght and there is a difference in the 2wd and 4wd versions.
Old Jan 30, 2011 | 07:55 PM
johnb3006's Avatar
johnb3006
yes. the plan was to swap bell housings and bolt the new one to my truck. the bell housing bolt up differently
Old Jan 31, 2011 | 12:05 AM
HotrodSmurf's Avatar
HotrodSmurf
if the tranny from the car was behind a 4 or 6 cylinder it would have a different pattern.
Old Jan 31, 2011 | 06:18 AM
Don Senkow's Avatar
Don Senkow
The pan fill and case fill bellhousings are different. Other than 6 cylinder, there should be 2 versions of pan fill, 1 for small block, the other was 351M. They would interchange on the transmission. The case fill small block has 2. 157 tooth and 164 tooth. The difference besides 7 teeth is the starter placement. (Flexplate is larger)
Old Mar 28, 2011 | 06:07 PM
302/C4's Avatar
302/C4
I have a 68/69 C4 that has the fill tube in the pan. The body of the trans mission is longer forward, so bell housing is shorter.I NEED A PAN/FILLER TUBE with Dip Stick. From what I can find is these were used in some mid to full size cars, Broncos and F-100 trucks from '69 into mid-70's. Said with a heavier output shaft and yoke with additional clutches. Code tag on mine is PEA M1.
bbf ford
Feb 17, 2015 08:33 PM
Old Coyote
Jul 7, 2013 06:58 PM
Old Coyote
20
May 27, 2013 03:41 PM
dino360
Oct 26, 2004 11:09 PM
Unglued
Dec 16, 2003 11:34 PM
