Wild speedo
Old Oct 24, 2011 | 09:39 PM
bryanlindborg600's Avatar
bryanlindborg600
Wild speedo
Ok guys, I've read some threads here and I'm still at a loss on this one.. My speedo will bounce like crazy during driving... Sometimes no movement at all.. But never readable or any where near accurate... I noticed today that it also was bouncing wildly at an idle, not in gear..? Any ideas would be greatly appreciated
Old Oct 24, 2011 | 09:51 PM
madpogue's Avatar
madpogue
No surprise that the speedo acts as it does whether at idle or in gear. The sensor (VSS) is on the differential, not on the transmission. If it were tied to what gear you were in, the speedo wouldn't work in neutral, even when it works normally. That's why it's on the diff. It's also the prime suspect in this case. Either the sensor itself is bad, or built up with metal shavings (it's magnetic), or what can also happen is that metal shavings will build up on the notches on the tone ring (the thing the sensor "reads") inside the diff. Remove and clean, inspect the tone ring thru the hole, try again. If it still bounces, replace the sensor. If it _still_ bounces, you may have to open up the diff.
Old Oct 24, 2011 | 09:55 PM
bryanlindborg600
I plan on inspecting the vss tomorrow after work.... Hopefully, but just to be clear when I say idle I meant the truck was not moving what soever.. It was just sitting out front of my house running... Thanks for the tip though, I will be inspecting the vss
Old Oct 24, 2011 | 10:34 PM
madpogue's Avatar
madpogue
Ah, I thought you meant you were coasting. But come to think of it, since it's magnetic, if either the sensor or the tone ring (why don't they just call it a "reluctor", like it is everywhere else?) is ooked up with metal shavings, I could see how that could "tweak" the sensor even when you're not moving.
Old Oct 25, 2011 | 09:39 AM
superduty4x4's Avatar
superduty4x4
If its bouncing when you aren't moving its probably the PSOM.
Old Oct 25, 2011 | 10:23 PM
bryanlindborg600
hey chase been doing alot of reading and came across an old thread i think was you that posted, a "reset" deal for the speedo.. involving holding the reset button and turning the key to the on postion. making the needle peg and go back to Zero.. well i did that and it did just that.. peg the speedo and returned to Zero.. got a code on the odo. E 08 5 if i remember right.... sorry been a long day and just remembered to post this... anyways does this still point to the psom... which sorry to say i don"t fully understand what it is and where is it... sadly i didn't get to looking at the vss today either.. any other info to aid my search would be greatly appreciated! thanks to all!!!
Old Oct 26, 2011 | 08:44 AM
superduty4x4
No clue on the code, but its probably just a calibration code.
If you were searching I'm surprised you didn't find one of my bazillion posts already PSOM (programmable speedometer/odometer module) is a small module that is integral to the speedometer (IE, you can't take it off, its built in). It receives the speed signal from the VSS and forwards the info to the PCM, which in an auto trans truck the PCM uses to control the trans. If you have a bouncing speedo in an auto truck, the PCM goes gonzo trying to figure out what's actually going on and it really beats on the trans. The only way to test the PSOM is to swap in a known good unit from another truck.
The PSOM also stores the mileage info, so if yours is bad and you swap out the cluster or speedo portion of the cluster whatever miles the donor rig had will show on your rig.
Old Oct 26, 2011 | 10:07 PM
bryanlindborg600
i'm hopefully gonna go junk yarding this weekend... work permiting, being that i have a manual im sure i need to find the correct cluster..or can i swap things around and make a auto work? also can i get one out of a bronco or any ford truck my yr or yr range? thanks for the help
Old Oct 26, 2011 | 10:42 PM
madpogue's Avatar
madpogue
Gasser cluster will probably not work. Obvious differences are fuel gauge callout and tach range. Gauges themselves are probably calibrated differently as well, and the pinouts might not be the same. I can check the EVTM tonite. Somebody did swap in just the speedo from a gasser, a Lightning to be exact, just to have a 140MPH dial.
Only difference between an automatic and manual cluster is the little callout for the tranny. It's just a liitle mechanical needle on a cable. If you get an auto cluster you should just be able to take the little panel off your existing cluster, that covers up where it would say "PRND21", and put it on the auto cluster. Or you could confound your passengers and just leave it there, and make them wonder why you have an automatic shift pointer on your manual truck.....
Edit -- UPDATE; checked the EVTM, and the pinouts are the same for gasser and diesel. Can't say whether the gauges will sweep properly, if you go this way. Oh, and disregard the "Unleaded Gasoline Only" admonition on the fuel gauge....
Old Oct 28, 2011 | 12:50 AM
superduty4x4
96-97 clusters will swap direct. 94-95 clusters in a later truck will give you fits because even though the pinout is the same, the printed circuit board on the cluster is different. If its a gasser I think 92-93 is in its own world too. A gasser cluster won't work in a PSD for obvious reasons, but you can swap just the speedo head like I stated earlier.
Old Oct 29, 2011 | 09:06 PM
bryanlindborg600
So the speedo head can cone out of just about any ford from 94 to 99 or do I need a specific yr to just swap the speedo head? I pulled my cluster out quickly before dark I'm not sure yet how to seperate the speedo part from the rest of the cluster.. Any more info would be great
Thanks
Old Oct 31, 2011 | 08:48 AM
Cratos's Avatar
Cratos
yes you can remove the speedo from the cluster .
Old Oct 31, 2011 | 09:17 AM
DIYMechanic's Avatar
DIYMechanic
I have a cluster out of a PSD. It has a bad voltmeter, but the rest works. PM me if you're interested. FWIW, the odo on this one shows about 260k miles.
Old Oct 31, 2011 | 10:05 AM
superduty4x4
Thanks
You have to pull the cover off, then the gauges pop out. There is a certain order that they come out and I can't recall right now.
Any speedo from 92-97 should work. One from a lightning truck goes up to 140mph I'd sell the complete cluster out of Whitey if you're interested, 168k miles and change.
Old Oct 31, 2011 | 10:06 AM
79OldBone's Avatar
79OldBone
I pulled the speedo from a 94 gasser and it worked fine I also have a full cluster from a psd that everything works fine if you need one! I found the gasser speedo before the psd cluster got to me in the mail so now I have a spare
Greg5OH
Jul 13, 2014 03:20 PM
thepitshop
Mar 30, 2012 09:36 PM
davisrats
16
Feb 11, 2007 11:22 PM
fordtrck302
25
Aug 19, 2005 04:05 PM
scooter_1968
Dec 15, 2003 02:07 PM
