window adj.
Old 10-28-2011, 01:44 PM
mkrog's Avatar
mkrog
mkrog is offline
Unhappy window adj.
Got a 57 F100 and the drivers door window ***** and binds when I try to roll it up or down, new glass run.Whats the fix?I have tried to adj. it .Do I need a new division bar?
Old 10-28-2011, 07:52 PM
rcjccobra's Avatar
rcjccobra
rcjccobra is offline
That's called "racking" and it's typically caused from the glass being cut too small.
Old 10-28-2011, 08:11 PM
spurredon's Avatar
spurredon
spurredon is offline
Out of everything I did to redo my '60, adjusting the windows were the hardest. Still have one that isn't perfect and I used the original glass.
Be patient and keep at it.
Old 10-28-2011, 11:13 PM
mkrog's Avatar
mkrog
mkrog is offline
It's the original glass.
Old 10-29-2011, 07:07 AM
Walston's Avatar
Walston
Walston is offline
It has been a few years since I did mine, but it sound like the division bar is either out of adjustment, moving or maybe needs replaced. The bar on the outside of the door could also be moving. Dennis Carpenter's catalog that you can download has a step by step procedure on how to replace the window system, it may be helpful. If the glass is original, one would think that it is sized correctly. Good luck.
stil190
01-14-2022 07:46 AM
art vandolay
08-25-2017 11:34 AM
smallello
06-02-2016 08:29 PM
'79Fordpilot
04-08-2012 01:15 PM
53ford
05-07-2006 12:10 PM
Quick Reply: window adj.
