window adj.
Old Oct 28, 2011 | 01:44 PM
mkrog's Avatar
mkrog
Unhappy window adj.
Got a 57 F100 and the drivers door window ***** and binds when I try to roll it up or down, new glass run.Whats the fix?I have tried to adj. it .Do I need a new division bar?
Old Oct 28, 2011 | 07:52 PM
rcjccobra's Avatar
rcjccobra
That's called "racking" and it's typically caused from the glass being cut too small.
Old Oct 28, 2011 | 08:11 PM
spurredon's Avatar
spurredon
Out of everything I did to redo my '60, adjusting the windows were the hardest. Still have one that isn't perfect and I used the original glass.
Be patient and keep at it.
Old Oct 28, 2011 | 11:13 PM
mkrog's Avatar
mkrog
It's the original glass.
Old Oct 29, 2011 | 07:07 AM
Walston's Avatar
Walston
It has been a few years since I did mine, but it sound like the division bar is either out of adjustment, moving or maybe needs replaced. The bar on the outside of the door could also be moving. Dennis Carpenter's catalog that you can download has a step by step procedure on how to replace the window system, it may be helpful. If the glass is original, one would think that it is sized correctly. Good luck.
stil190
Jan 14, 2022 07:46 AM
art vandolay
Aug 25, 2017 11:34 AM
smallello
Jun 2, 2016 08:29 PM
'79Fordpilot
Apr 8, 2012 01:15 PM
53ford
May 7, 2006 12:10 PM
