Bucking when cold
Old Feb 14, 2013 | 11:58 AM
  #61
Hussler's Avatar
Hussler
Might want to check EOT sensor either with a scanner or ohm-meter. It affects timing big time. If you unplug it the CEL will set and PCM will assume a default of 212 degrees F. Easy and cheap test.
Old Feb 14, 2013 | 12:35 PM
  #62
KP1001's Avatar
KP1001
Originally Posted by Hussler
Exhaust Back Pressure Valve (EBPV) still plugged in? Sounds like weather is starting to get cold and it is activating on cold start ups.
Notice that you have 3.55 gears. How do you like them? I have 4.11 (or 4.10 whichever) and always wanted 3.55, any idea how much $ to convert?
Old Feb 15, 2013 | 03:12 AM
  #63
tiopet's Avatar
tiopet
I will measure the resistance of the EOT on monday in the workshop.
It's too cold to do it outside right now.
I was thinking, can the EOT sensor do this; At highway speeds, there is a slight stutter/hesitation and I took the van to the dealership last summer.
They connected a monitor thingy and took a test drive.
The result was that the fuel injection system had a 3 volt drop at that moment when it stutters.
At warm; there is no stutter/hesitation on full throttle, only on maintaining the speed.
At cold; it won't increase to higway speeds until it's warmed up a little, like we discussed earlier in this post.
Old Feb 18, 2013 | 09:39 AM
  #64
tiopet's Avatar
tiopet
EOT was measured today at 3 different temperatures, all OK.
IAT was perfect also.
ECT was way off scale??? It shows 194,5 Ohms at 30 degrees celcius.
It should show 24 k Ohms at 30 Degrees celcius.
Is the cooling water sensor giving me all this trouble
Old Feb 18, 2013 | 10:45 AM
  #65
fordpride's Avatar
fordpride
No. PCM doesn't use ECT
Old Feb 18, 2013 | 08:14 PM
  #66
KP1001's Avatar
KP1001
Noticed you have a 1 ton van. Any idea what the gear ratio is on the 16 passenger vans approx 2005-2007?
Old Feb 18, 2013 | 08:53 PM
  #67
tshrager's Avatar
tshrager
Check the axle tag....
Old Feb 19, 2013 | 08:14 PM
  #68
KP1001's Avatar
KP1001
I dont own one but I had driven one a few years back and remember being impressed with the way it ran. Thought that rear end may help contribute to my decision regarding my next purchase.
Old Feb 19, 2013 | 08:48 PM
  #69
oldbird1965's Avatar
oldbird1965
On the drivers door jam there is a axle code. Do a search and find what it means.
MEISTERSNFB
Jan 10, 2018 08:36 PM
blackestate
Nov 6, 2014 04:05 PM
w_huisman
Nov 8, 2013 06:00 PM
Yeti1234
28
Jun 3, 2011 09:42 PM
sean23johnson
Jan 12, 2007 06:24 PM
