A/C TEMP PROBLEM, PLEASE HELP!
Old Oct 27, 2011 | 08:52 PM
Crownline04's Avatar
Crownline04
2004 F150 with Auto Climate. If I put the setting on 60 I get Ice cold A/C, If I change it one click to 65 I get VERY hot heat. There is no adjustabilty.
I just replaced the actuator with the updated one and that did not fix my issue? Any suggestions besides dealer?
Thanks
Old Oct 27, 2011 | 10:45 PM
Crownline04
23 views and no response? Come on guys I need some help with this...
Old Oct 28, 2011 | 12:37 PM
tooldad's Avatar
tooldad
First thought too was the actuator based on my personal experience. Second thought would be an issue with the cotrol unit. There is a combination of button pushes that (on control) that will show any related error codes, but I do not know how to do. Sorry. I just watched a tech do it once. So, short of trying to replace the control unit, I am at a loss to help. Good luck.
Old Oct 28, 2011 | 05:12 PM
aquaman's Avatar
aquaman
Maybe a bad connector connection behind the ETAC?
My problem is I get heat even with the temperature set to minimum. Stupid blend door must not be closing all the way.
terryingeorgia
2004 - 2008 F150
19
May 26, 2014 07:59 PM
bigwiege
2004 - 2008 F150
Jan 31, 2011 07:07 PM
mohle
Nov 11, 2010 08:47 PM
cdestuck
2004 - 2008 F150
Oct 20, 2009 08:52 PM
hank_48
Dec 26, 2002 12:40 PM
