Thinking about using northland 15w 40 in my powerstroke instead of rotella? It has rotella in it. I have used northland in all of my older diesels with good luck but thats what i started them on.
Is the northland CI-4 rated. These trucks use oil pressurized up to around 3000psi to fire the injectors so the oil needs the additive pack in the CI-4 oil to prevent foaming.
