C6 question here.
Old Oct 26, 2011 | 11:26 PM
WideLoadTimmy's Avatar
WideLoadTimmy
C6 question here.
I have a 1984 F-150 4.9 and the C4 is not long for this world. I'm thinking about a C6 to add overdrive. What I would like to know is do I need one specifically for a 4.9 or would any C6 do? Also, would I need any ancillary parts like cables? I would bet I would need to.modify or find a new driveshaft as well.
Old Oct 26, 2011 | 11:30 PM
85e150's Avatar
85e150
C6's are not OD.
If you want OD, get an AOD from behind a 300 or SBF V8 from an '88 to '93 vehicle. (early models are trouble).
You need a TV cable and will probably have to fiddle with your shift linkage a bit.
All these transmissions have integral bell housings, so the trans must come from behind a 300 or 302/351w motor.
Old Oct 26, 2011 | 11:38 PM
WideLoadTimmy
Originally Posted by 85e150six4mtod
C6's are not OD.
Thank you for the help and for clearing up some confusion on my part. That's pretty much what I needed to know. I thought about a manual swap but I don't wanna mess with the finding all the clutch stuff. I'm new to these trucks and I'm still searching auto to manual conversions. Do you think the O/D auto would be less time consuming or about the same?
Old Oct 26, 2011 | 11:44 PM
85e150's Avatar
85e150
AOD is almost the same length as the C4, so it might be a very basic bolt in to start with. IIRC, you need an AOD-specific flywheel, so double check that.
MT conversion requires clutch and brake pedal installation. If you like laying on your back in a cramped location for a couple hours and working at odd angles with crap falling in your eyes....you'll love that part of it.
Old Oct 26, 2011 | 11:52 PM
WideLoadTimmy
I have had the displeasure of plenty of interior work. I hate it. I'm gonna have to do it anyways for this stupid throttle cable. There's no extra holes that need drilling or brackets that need to be made? Just a set of pedals? Are they cable clutches?
Old Oct 27, 2011 | 01:04 AM
85e150's Avatar
85e150
Your throttle cable from the pedal to the carb remains the same. It's from the carb to the trans that needs attention.
Clutch pedal installation starts with removing the existing brake pedal.
Yes, you would have to open up the firewall.
Hydraulic would be best for the clutch.
Are you going AT (AOD) or manual? IMO the AOD is the least amount of work.
Old Oct 27, 2011 | 06:45 AM
WideLoadTimmy
Well then I better start looking for an AOD. Is the tranny cross member the same or would I have to modify or replace mine? As far as the throttle cable goes, I have to replace that because it broke and I have it stuck together with a butt connector until I can get the replacement ordered.
Old Oct 27, 2011 | 01:52 PM
85e150's Avatar
85e150
IIRC, the cross member needs a little adjusting, a different mount, possibly a reversal or to be turned upside down. Not a major mod.
dldjeep
Aug 11, 2013 06:30 PM
84ford150
26
Aug 21, 2008 01:09 PM
tprice
1978 - 1996 Big Bronco
25
Feb 16, 2005 10:34 AM
warren b
Apr 21, 2003 05:31 PM
desperado_18_2000
Jul 15, 2002 12:05 AM
