steering pitman arm
Old Oct 25, 2011 | 11:28 AM
sunbelt57's Avatar
sunbelt57
steering pitman arm
I'm stripping a '76 F150 and I want to disconnect the whole front end and stash it in the garage. Everything's loose except where the steering gear box connects to the idler arms and so forth. I sprayed some penetrating fluid on the spline end of the pitman arm and pounded on it with a hammer (not too hard). I'm wondering if I need a puller to remove it. I'm trying to not damage anything in case I want to sell it later.
Old Oct 25, 2011 | 11:48 AM
montana_highboy's Avatar
montana_highboy
Originally Posted by sunbelt57
I'm wondering if I need a puller to remove it..
Yes you do, preferably a quality heavy duty puller, the cheapie pullers e.g. Harbor Freight, tend to just strip the threads and/or break when put up against a stubborn pitman arm.
jerryst
Nov 15, 2016 09:10 PM
Road Warrior 95
Jul 5, 2014 09:55 AM
MIKEDENGINEER
May 9, 2014 07:50 PM
fordguy300
Mar 21, 2009 12:52 AM
jak1212
Nov 27, 2001 03:47 PM
