What do you mean by cab lights? Extra driving lights on top of the cab, or an extra interior light in the cab? You should already have an interior cab light...it comes on when you rotate the headlight switch **** all the way counterclockwise.
If you mean extra lights on the cab...yeah, you can do that but use a new/separate circuit and switch for that...the wiring in your truck is 43 years old and brittle and finicky...best to not disturb it.
As for wiring the parking lights to stay on with the headlights...it has been done and there is a thread on here somewhere...use the Search function...as I remember it required using a relay of some sort. Again, when old wiring works okay it's best not to tamper with it IMO.
I doubt it...lots of changes between 68 and 78. Don't know for sure but I would bet the switches and wiring is way different. 68 through 72 is pretty much the same, 73 was a transition year, and 74 through 79 were dent-side trucks...lots of differences from the 68-72 bump sides.
Ya I know this. I just want to leave my park lights on and geadlights
