lighting problem
Old Oct 24, 2011 | 09:58 PM
koch26's Avatar
koch26
lighting problem
I have 68 ford and when I turn my headlights on my parking lights turn off
koch26's Avatar
koch26
Does anyone know why?
Old Oct 25, 2011 | 08:02 AM
tmcalavy's Avatar
tmcalavy
Well, as long as your taillights stay on this is normal...that's the way Ford wired it. My 69 F250 does the same thing.
Old Oct 25, 2011 | 08:56 AM
koch26's Avatar
koch26
So what if I put in cab lights? Do I need another switch? And can I wire my park lights to stay in with my head lights?
Old Oct 25, 2011 | 09:37 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
They can be wired to to the later arrangement, and add cab lights. Someone with a set of diagrams should be able to tell you exactly how to wire.
Old Oct 25, 2011 | 10:14 AM
tmcalavy's Avatar
tmcalavy
What do you mean by cab lights? Extra driving lights on top of the cab, or an extra interior light in the cab? You should already have an interior cab light...it comes on when you rotate the headlight switch **** all the way counterclockwise.
If you mean extra lights on the cab...yeah, you can do that but use a new/separate circuit and switch for that...the wiring in your truck is 43 years old and brittle and finicky...best to not disturb it.
As for wiring the parking lights to stay on with the headlights...it has been done and there is a thread on here somewhere...use the Search function...as I remember it required using a relay of some sort. Again, when old wiring works okay it's best not to tamper with it IMO.
Old Oct 25, 2011 | 11:30 AM
koch26's Avatar
koch26
Ok I was just wondering if something was wrong thanks
Old Oct 25, 2011 | 11:42 AM
koch26's Avatar
koch26
So if I use a newer switch and not even touch the wording they will come on still? Say like a 78 light switch?
Old Oct 25, 2011 | 10:23 PM
tmcalavy's Avatar
tmcalavy
I doubt it...lots of changes between 68 and 78. Don't know for sure but I would bet the switches and wiring is way different. 68 through 72 is pretty much the same, 73 was a transition year, and 74 through 79 were dent-side trucks...lots of differences from the 68-72 bump sides.
Old Oct 25, 2011 | 11:35 PM
koch26's Avatar
koch26
Ya I know this. I just want to leave my park lights on and geadlights
Old Oct 26, 2011 | 08:13 AM
tmcalavy's Avatar
tmcalavy
Search the forum for headlights/parking lights...there's a thread on here that tells you how to wire in a relay to get what you want.
Old Oct 26, 2011 | 09:54 AM
koch26's Avatar
koch26
Ok thank you
Leathers65
Jul 17, 2017 10:49 AM
mcghan
Oct 9, 2011 06:02 PM
$Simpleman76
Mar 22, 2007 06:29 PM
The67Beast
Sep 25, 2006 11:06 AM
truck35
Jun 6, 2002 04:14 PM
