Running / marker lights
Old Oct 24, 2011 | 02:36 PM
91dirtydiesel's Avatar
91dirtydiesel
I tried searching but coulndnt really find what I was after.
Looking to light my truck up, putting those amber rectangle lights under the front bumper, rear bumper (red for brakes), under the sides, and cab lights.
Anyone like any specific types of light or pics of how your trucks look at night?
Lastly, on the wiring the red ones with the brakes, would it work to splice it into my trailer brake lights?
Thanks for any ideas / suggestions
Old Oct 24, 2011 | 03:29 PM
ford1977owner's Avatar
ford1977owner
have you check LMC truck
Old Oct 24, 2011 | 03:39 PM
Edgethis's Avatar
Edgethis
I would def recommend using LED bulbs to reduce the draw on the light switch as well as they'll put out better light. I have seen kits for tailgates but not for the front or sides, except the dually fender lights.
Cab lights are easy and cheap, I installed them on my Chevy I had.
Old Oct 24, 2011 | 07:45 PM
91dirtydiesel
Ok good point about the LED, ill check my lmc catalog. How about the rear ones wired into the towing hookup?
Old Oct 24, 2011 | 07:50 PM
Edgethis's Avatar
Edgethis
That sounds like it would be a good spot to wire them in. except if you ever wanted to tow a trailer. I'd say wire them in to the trailer hook-up for now. See how you like them then maybe wire them into the rear lights to retain use of the trailer light hook up in the future.
Old Oct 24, 2011 | 07:59 PM
91dirtydiesel
Could I splice it into it? Rather then making it direct? So the trailer still works?
Old Oct 24, 2011 | 08:05 PM
Edgethis's Avatar
Edgethis
To be honest, i wouldn't splice into the trailer wiring. That wiring always hangs down and gets the worst of the road salt/rain/snow/mud/squirrel you name it. I'd either plug it into the trailer port or splice in into the rear lights where the wires and splices are tucked up in the bedsides.
Old Oct 24, 2011 | 08:57 PM
Diesel_Brad's Avatar
Diesel_Brad
Deffinatly LEDs. the electrical system on these trucks is under built so a lesser draw light would be your best bet
Old Oct 24, 2011 | 10:45 PM
KC92F150's Avatar
KC92F150
Check these lights out...you can put them anywhere. Can hardly tell they are there when not on. Hope this helps.
Universal L.E.D. Indicator Bulbs - Speedway Motors, America's Oldest Speed Shop
Herr Geist
Jun 28, 2012 06:27 PM
EpicCowlick
6.7L Power Stroke Diesel
44
Jul 4, 2011 01:51 PM
jndinmo
All Things Towing
May 14, 2011 02:24 PM
krejci.mike
Offroad & 4x4
Nov 26, 2008 11:01 PM
Buzz Cut
Feb 5, 2004 11:52 PM
