no tach movement,new camshaft pos. sensor installed
Old Oct 23, 2011 | 05:02 PM
mark venegas's Avatar
mark venegas
my excursion would not start,had no codes. installed new cps and started right up yesterday,today would not star on first try notice no tach movement.tried second time and started after along crank,no tach movement at idle or stop but moves when driven.Any ideas on whats going on here. Thanks in advance,hope someone can help
Old Oct 23, 2011 | 05:13 PM
BLADE35's Avatar
BLADE35
what year
scan for codes
and Welcome to FTE
Old Oct 23, 2011 | 05:51 PM
BLADE35's Avatar
BLADE35
check the EGR Valve out could be slightly stuck open
but could be HPO leak
Old Oct 24, 2011 | 11:03 AM
mark venegas
2005,no codes, thanks for the help
Old Oct 24, 2011 | 11:40 AM
npccpartsman's Avatar
npccpartsman
So the tach wouldn't register after the truck was started?
On an 05, no start with no codes I usually suspect an HPO leak also. Search STC fitting for MUCH more information.
Old Oct 24, 2011 | 12:44 PM
dchamberlain's Avatar
dchamberlain
It sounds like the tach is out of alignment. That can be fixed by resetting the cluster. The starting problem could be a High Pressure Oil problem or it could be a FICM problem.
As far as codes, what are you using to try to read them? Some code scanners won't read codes from a Powerstroke.
To reset the cluster, hold the trip meter reset button down and turn the key on. The cluster will enter it's test mode. Press the trip meter button until the gauges sweep. That should realign them.
DieselCamper
32
Jun 22, 2016 05:12 PM
rolsmojave3
Jun 14, 2010 03:10 PM
Sycostang67
28
Feb 14, 2010 02:04 PM
trooperkelly
Jan 14, 2006 08:29 AM
jrfateranger
1983 - 2012 Ranger & B-Series
May 7, 2005 08:09 PM
