why NO BOOST!!!??????
Old Oct 23, 2011 | 03:26 PM
deceptichop's Avatar
deceptichop
thank you for opening my thread gentlemen.
Ok, here we go. I am absolutely stumped and frusterated over this.
My girl is a 94 7.3 with factory turbo. She has 203k miles. No matter what I do, i can not get over 6.5 psi out of my turbo!!
I have a brand new IP turned ALL THE WAY UP! Brand new Stage 1 injectors from DPS. The 2.5 pipe exiting out of the rear of the turbo. And a very impressive homemade 4" air intake. AND the turbo's wastegate is wired shut!!!!!
What is going on here? And I know the turbo works. I hear it spooling up all the time. Music to my ears. But Im at a loss here.
any ideas guys? Thank you in advance
Old Oct 23, 2011 | 03:29 PM
91dirtydiesel's Avatar
91dirtydiesel
Intake or exhaust leak?
Old Oct 23, 2011 | 03:47 PM
deceptichop
negative. no leaks. Thanks for the reply Dirty
Old Oct 23, 2011 | 04:12 PM
GHeTTo JOe's Avatar
GHeTTo JOe
how do you have the wastegate "wired" shut?
Old Oct 23, 2011 | 04:14 PM
beisel91's Avatar
beisel91
How much load do you have on it ?
Old Oct 23, 2011 | 04:18 PM
91dirtydiesel
Is it plugged too? Or just unhooked the rod and wire it?
Old Oct 23, 2011 | 04:27 PM
deceptichop
I adjusted the WG to the fully closed position to get full boost. It went from 4 psi to 6.5 after doing this.
can it just be that I have a 2.5" downpipe vs the aftermarket 3"?
Old Oct 23, 2011 | 04:32 PM
GHeTTo JOe's Avatar
GHeTTo JOe
does she smoke?
Old Oct 23, 2011 | 04:36 PM
deceptichop
Originally Posted by GHeTTo JOe
does she smoke?
she used to smoke black until i advanced her timing. Runs MUCH better with the advancement and more like a gray haze when I get on it hard.
Old Oct 23, 2011 | 04:45 PM
GHeTTo JOe's Avatar
GHeTTo JOe
do you have a pyro? how hot does she get? i would have to guess if you have your pump maxed out for fuel and are not rollin like a freight train then there is an issue with not getting fuel? everyone says you can melt em down easily so i wonder if you are not getting enough fuel
Old Oct 23, 2011 | 04:46 PM
deceptichop
no towing. just getting on her, HARD on the street. 2nd, 3rd, and 4th gear taching almost 3000rpm. Pyro gets to 1000 and boost only 6.5psi.
91dirtydiesel
My factory 93 with stock pump not turned up with the factory down pipe will make 8.5psi. Being that you said u maxed pump and adjusted wg and only get 6.5 makes me still wonder about uppipe/crossover leak
Old Oct 23, 2011 | 04:49 PM
deceptichop
Thanks Ghetto. Ya man, Autometer Pyro and boost. After maxing out the IP, I noticed a very nice increase at the 1300/1500 rpm level. So I know she's getting fuel. Actually with all my mods, I think its a toss up between the max fuel and the 2.5" downpipe as far as the difference that I felt.
well, maybe I do have a leak somewhere, but I just cant hear it because her motor is so loud?
Old Oct 23, 2011 | 04:50 PM
deceptichop
hmmm, you might be on to something there Dirty.
Old Oct 23, 2011 | 04:53 PM
91dirtydiesel
Just run your fingers around the seams when running (cold) might feel warm air or hear it
