Injector stuck open
Help me please!!
Let think about this some more.
Do you have a CEL lit, if so, scan the computer for trouble codes & post All code Numbers, as they can offer up good trouble shooting clues.
If no codes, did you pull & inspect all of the other spark plugs???? If so & they all looked ok, maybe suspect a wiring or computer ground switching driver problem.
With #1 plug looking as you described, it holding fuel pressure ok with the key off, but pressure leaking down with the key on & still doing it after the injector was replaced, it sounds to me like an electrical problem, as the injectors have B+ to them when the key is in the run position.
Maybe a wiring problem on the injectors ground return to the computer, or a computer driver problem, if the driver isn't switching the injector ground connection completely off. SO, try disconnecting the #1 injector when leaving the key on & see what happens with fuel pressure.
If pressure holds, do a voltage check to ground, across the contacts at the injectors disconnected plug with the key on/engine off & let us know what you find.
I think we're on the same page... Tried all of this yesterday after i made the post...
No Engine warning lights are on...
I did pull all the plugs the others were getting pretty white like they were running lean... Cycled key with all plugs out and #1 cyl. filled with fuel...
Fuel rail does hold pressure with the #1 injector unpluged, and tested for ground at the plug with the key on/engine off return ground wire is grounded... Also checked for short to ground at #1 injector plug with harness unpluged from ECM (not grounded)... So that should rule out the harness right??
To me sounds like I have a bad ECM?
I can order one from Autozone... Does it need to be flashed by a dealer or am I ok just to swap it out...
Thanks for your help!
OK, good trouble shooting & feedback. From what you've posted, I agree it sounds like a computer ground switching driver problem for #1 injector.
If you know an electronic tech, he may be able to replace the driver or it's control circuit, or what ever is bad & it'll likely cost way less than a reman computer.
Be sure to replace the computer with a matching part number, then go through the cold & warm idle relearn proceedure with the replacement computer & be good to go without driveability problems, as the computer can usually learn the remainder of what it needs too, as we drive. In any case the short & long version Ford computer relearn driving routines have been posted on the forum, so a search will turn them up.
Let us know how it goes.
I don't rightly know why it didn't set a CEL. My 94 Taurus recently had a random stall, that was caused by spark going missing. It was traced by process of elimination to the computer, it too didn't set a CEL or store any trouble codes.
I suppose the circuit or faulty component wasn't being monitored by the CEL circuit for self diagnosis.
