I have the Stanadyne filter with the heater that slides in the top for my e-fuel.
How did you guys wire up the heater? I have everything else figured out, but that.
I'm assuming it should get it's own relay?
What turns on the relay? Should I pull 12V from the original fuel bowl heater wire, just like I will for the relay for the pump?
What size fuse should I use for the heater. It is a 100 watt heater I think.
Anywhere online to buy those connectors that fit inside the factory fuse panel for the relays and a crimper for them? I don't even know what they are called to even start a search, haha.
