10.25" rear end question
Old Oct 22, 2011 | 12:07 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
I have searched this area (at least as far as it will let me filter) searched on-line and casnnot find a key piece of information. What is the pre-load for the differential bearings on a 10.25" rear? I have the pinion information, backlash etc. but no differential bearing other than cap torque.
BTW, I am not unfamiliar with rebuilding rear ends, but still prefer the trusty 9".
Thanks,
Old Oct 22, 2011 | 04:43 PM
LeoJr's Avatar
LeoJr
I'm watching this thread as I have to remove the yoke and install the plastic protector ring. I believe the previous owner did not take note of the nut's original location so I don't trust its location now and believe I need to start from scratch.
Old Oct 22, 2011 | 05:32 PM
85lebaront2
The only thing you need to be sure of is that you do not exceed the pinion bearing preload.
Old Oct 23, 2011 | 07:09 PM
85lebaront2
I finally found it. A 1991 service manual says after setting the backlash and getting a good pattern add .006" to each side to set the bearing preload.
Kenneth Carroll
2009 - 2014 F150
Aug 16, 2018 09:36 AM
crucialprospect
21
May 13, 2018 04:00 PM
daves1148
1983 - 2012 Ranger & B-Series
Aug 1, 2008 11:10 PM
wls
16
Dec 19, 2007 09:46 PM
