Sponsored by: Real Truck
Aux switches on dash?
Old Oct 22, 2011 | 06:13 AM
redbull660's Avatar
redbull660
I just bought a used 2008 ford f350, it didnt come with an owners manaul. Can someone tell me what the 4 Aux switches are for on the dash. I am assuming they are to hook up stuff like fog lights, etc... If they are where are the plug in ends to use them. Thanks
Old Oct 22, 2011 | 08:26 AM
northwindone's Avatar
northwindone
They are known as upfitter switches and you are correct, they are basically for whatever accessories you want to hook up to them.
Here is a link to the owners manuals from the Motorcraft Technical Resource website:
http://www.motorcraftservice.com/vdi...&menuIndex1=24
The manual says:
There will also be one power lead for each switch found as a blunt-cut
and sealed wire located below the instrument panel and to the left of
the steering column. They are coded as follows:
Switch Circuit number Wire color Fuse
AUX 1 CAC05 Yellow 30A
AUX 2 CAC06 Green with Brown Trace 30A
AUX 3 CAC07 Violet with Green Trace 10A
AUX 4 CAC08 Brown 15A
The manual goes into more detail as far as the location of the relays, igntion switch position, etc...
Fordboy880
Jun 22, 2018 05:01 PM
The_SnowMan710
Electrical Systems/Wiring
Mar 30, 2009 11:36 PM
greg12345
Jan 7, 2009 03:56 PM
01stroker
May 12, 2007 04:53 PM
874x4
Jan 18, 2007 02:30 PM
