does any one know if you can put a cab air filter in a 04 f350 that did not come with one if so can you give me the part #'s i would need to put it in thanks
no i have no fumes but i take some long trips on the hwy and i just don't want all the road graim on me and the inside of my new truck i bought it off the lot or i would have had it put in new so i'm just trying to get the part numbers i need to order it for my truck
Here ya go. Note I have not identified a stocking supplier yet.
AIR FILTER International part #1840752C91
AIR FILTER FRAM P/N CA8039 Cost $16.99 Autozone
AIR FILTER K&N 332248 Advance Auto Parts $45.48
AIR FILTER FRAM P/N CA8039 Advance Auto Parts $16.88
AIR FILTER ACCEL KP3419 Advance Auto Parts $40.99
AIR FILTER WIX 42731
OIL FILTER STP P/N S9549 Autozone $10.99
OIL FILTER NAPA P/N FIL 7314 NAPA $22.99
OIL FILTER K&N HP2010 Advance Auto Parts $9.99
OIL FILTER FRAM CH9549 Advance Auto Parts $19.99
OIL FILTER MOTORCRAFT FL2016 Advance Auto Parts $19.98
OIL FILTER WIX 57314
thanks guys but i need to know if it will fit in the truck or do i have to get other parts from ford THE TRUCK DID NOT COME WITH A CAB FILTER FROM THE FACTORY if not how do i put it in my truck
Call Cab Fresh at 1-800-457-3739. I ordered a #19200 which is an F-2000 New Super Duty Filter kit. It screws down over to stock cowling by the driver's side wiper. Their part number for the replacement filter element is R19200. The filter kit includes one plastic housing to screw down and a single filter for $50. The replacement element is $18 It filters pretty well for dirt and pollen, but will not cut down on odors.
As far as my limited memory can recall, there is NO OEM Cabin filter for the F-250s and F-350s. I installed a kit for my F-150 that is the same as the factory kit. Ford charged me around $75 for that factory kit. When I bought my F-250, I was surprised that there was no factory kit and after much research, I bought the after market one I spoke of before.
thanks for the info i'll lokk into it when i get down south that's where the dealer is i got the truck from i'll have to talk to them and see what i can do
