Don't You hate It ...
Old Oct 23, 2011 | 01:38 AM
MauleOne's Avatar
MauleOne
Don't You ...
F350-6
Yeah, you should always check that last maintenance function when something immediately goes wrong.
I have not checked the fuel pressure before. No before and after reading to work with.
The packing around the fuel pressure regulator plunger looks pretty bad. It could be causing the low fuel pressure.
I will finish the 50 cent mod tomorrow and think about further troubleshooting the fuel pressure. Might wait until I can get a new packing for the plunger.
Old Oct 23, 2011 | 02:04 AM
Skip1970's Avatar
Skip1970
are people installing filters before the pump? i thought the pumps were in the tank?
Old Oct 23, 2011 | 09:45 AM
ToMang07's Avatar
ToMang07
Stock, there are screens (that get blocked easily) in the tank, and the fuel pump is mounted on the frame, right under the driver's seat.
If you do the hutch/harpoon mods, you remove the screens and are supposed to install an actual pre-pump filter.
Old Oct 23, 2011 | 05:11 PM
Skip1970's Avatar
Skip1970
well heck good to know the pumps not in the tank... couldnt you just not do the mods and put a pre pump filter on it anyhow ?
Old Oct 23, 2011 | 05:15 PM
ToMang07's Avatar
ToMang07
You might want to look up the Hutch Mod.
Welcome to guzzle's In-tank Hutch Mod Web Page
The problem is the screens getting blocked. As well as air getting sucked in at below 1/4 tank. (Very common.)
Old Oct 23, 2011 | 09:08 PM
timmyboy76's Avatar
timmyboy76
I think franko72 hand an issue with an "open" regulator return. He installed the FRx and now/since, been banging at 72-ish psi
Old Oct 24, 2011 | 09:18 AM
MauleOne's Avatar
MauleOne
I am finishing the 50 cent mod. Tried running it yesterday. Would start ok but sounded rought also white smoke out of exhaust.
I don't have a code reader (will be forced to buy one now) but I used to hear my injectors on my radio set to AM and between stations. They used to sound very strong. Now they all sound very weak and I can barely hear them.
ICM ?
I don't know that low fuel pressure would cause this problem.
I have ordered rebuild kit for FPR but tomorrow I leave for two weeks on my next work shift.
Old Oct 24, 2011 | 10:24 AM
MauleOne's Avatar
MauleOne
Don't You ...
Not ICM, I meant Injector Driver Module, IDM
Old Oct 24, 2011 | 12:04 PM
timmyboy76's Avatar
timmyboy76
i used to have 70+psi with the first gen FRx, then it started to climb/spike. I took apart the regulator, wetsanded the plunger, and clipped a coil off the spring. Now its a steady 66psi, with a 2-4psi drop when towing/in the turbo....The injectors went from being "tapping" to a no tap, and couldnt be more stoked.
Old Oct 24, 2011 | 12:37 PM
MauleOne's Avatar
MauleOne
Don't You ...
All my injectors sound weak and I am blowing white smoke. Sure can smell the unburned diesel out the exhaust.
Any suggestions?
Old Oct 24, 2011 | 02:44 PM
MauleOne's Avatar
MauleOne
Don't You ...
Ohmed out the injectors and glow plugs. All with in limits.
It has to be one of the engine sensors has failed and is giving the IDM a false signal.
I am running out of time as I have to be on a plane in the morning.
Any one have any ideas that don't include using an code reader. I can order one but that won't help now.
Old Oct 24, 2011 | 02:50 PM
timmyboy76's Avatar
timmyboy76
i have a "link" saved, unfortunetly im at a different computer. It involved the MAT sensor, which, when bad, made the truck blow white smoke. Believe its the sensor located at the bottom of the spider assy. try unplugging it, and give ur a shot..if so, its a delphi ts10098, i believe, but will check my "saved" ebay account, i have it there...yeah, thats the #..worth a shot
Old Oct 24, 2011 | 03:13 PM
  #28
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Any suggestions?
Sounds like not enough fuel, especially since the UVCH is good. Do you get a solid fuel flow from the fuel bowl drain with KOEO? If you have air, might as well blow back thru the lines to the tank. I know the Hutch/Harpoon are fresh, but if it isn't getting fuel it just makes sense to do the routine troubleshooting, IMO.
Old Oct 25, 2011 | 08:53 AM
  #29
MauleOne's Avatar
MauleOne
I disconnected the IPC and the truck runs good enough that I will drive it to work today. It is that or take a cab.
I will order a scanner from Clay for better troubleshooting than this hunt and peck stuff.
Hopefully I can get it fixed when I return from my two weeks on shift.
Old Oct 25, 2011 | 01:31 PM
  #30
timmyboy76's Avatar
timmyboy76
https://www.ford-trucks.com/forums/1...ke-help-2.html
