I'm thinking about doing mine just for the hell of it, since I have a 1,700 mile trip coming up in a couple weeks. I'm gonna tighten down the injectors and rockers while I'm in there. Just really don't want to get stranded that far from home.
I will have the valve covers off and report what I find asap.
If there wasn't a loose connector and the entire bank went down one bad solenoid can do that. While the valve cover is off is a great time to ohm out the individual solenoids, as well as the GPs.
How soon after the in tank mods did this happen? There's always a chance something got messed up inside the tank if it happened right away. If that's the case, pull the hose off the back of the fuel pump and stick a short hose into a can of diesel and onto the pump and check the pressure again.
