died unexpectedly
Old Oct 21, 2011 | 08:46 AM
joekacker's Avatar
joekacker
died unexpectedly
hey I have a 91 f150. I was driving this morning nothing was out of the norm. I came to a stop sign and started to pull off and truck just died. now it wont start at all anyone know what may have happened my battery and all That is right. it just wont fire. it turn and turns but no start. timing chain. or something. any ideas. im on the side of the road this sucks
Old Oct 21, 2011 | 08:56 AM
chard17's Avatar
chard17
Can u hear the fuel pump run when u turn the key on? my 88 did the same thing. Checked for spark and had no spark. Replaced the ignition module still wouldn't start. Went to pull a part picked up a like new coil and the relays gthat mount on the side of the air box. Got home changed the relays and its been runnin ever since.
Old Oct 21, 2011 | 08:58 AM
chard17's Avatar
chard17
If u can't hear the fuel pump id say prob relays. There are two relays on is for fuel pump and the other is ignition. When mine went bad I had no fuel pump and no spark
joekacker's Avatar
joekacker
not hearing the fuel pump prime the system when I turn the key that may be it
Old Oct 21, 2011 | 09:41 AM
joekacker's Avatar
joekacker
no spark coming through the system
Old Oct 21, 2011 | 09:44 AM
joekacker's Avatar
joekacker
where are these relays located
Old Oct 21, 2011 | 10:25 AM
chard17's Avatar
chard17
I have a 300 6 in my truck and they were bolted on the air box!!
Old Oct 21, 2011 | 11:08 AM
SideWinder4.9l's Avatar
SideWinder4.9l
No...Should be a seperate box BEHIND the airbox......Has a ford logo on it..
As for the fuel issue...Check the inertia switch...passenger side kick panel....Pull it out...and its a big red button.....
Old Oct 22, 2011 | 02:16 AM
chard17's Avatar
chard17
Side winder ur thinking to new 87 to 91 only had two relays in a small box that's not marked. The 92 and newer had the ford marked box mounted separate from air box about 8 or so inches long with relays and several fuses inside it.
Old Oct 22, 2011 | 02:24 AM
SideWinder4.9l
Dang....Your right....Thinking cap has shrunk a tad lately....
Old Oct 22, 2011 | 05:38 AM
Slip ford man's Avatar
Slip ford man
Some spark check help here Part 1 -Ford Ignition Module Test. Fender Mounted Module (ICM).
Old Oct 22, 2011 | 03:21 PM
joekacker's Avatar
joekacker
thanks I did some more research and it seems to lead me to the icm, Im going to swap that out today and see what happens
Old Oct 22, 2011 | 05:26 PM
Slip ford man
Be sure to apply a heat sink paste to the back of it.
Neoforcer
1997 - 2003 F150
Aug 1, 2016 05:04 PM
stsscott
41
Apr 11, 2014 02:26 PM
phils88150
Apr 6, 2008 11:43 AM
absouloote
Aerostar
Jun 9, 2004 04:43 PM
