Oil catcher...
Old Oct 21, 2011 | 08:18 PM
johnthoms's Avatar
johnthoms
A five gallon home depot bucket fits rite under drain on my 06 f350 never had problems with splash cause there is only 1 inch of space and holds all there oil in one shot, plus when u go to get rid of oil at recycler pop off lid pour carefully and your done in 45 seconds, my normal drain pan for other cars just seems to make more trouble than it's worth, but great for 5-8 qts not 13-15
Old Oct 21, 2011 | 09:39 PM
Big Red 5205's Avatar
Big Red 5205
I've been using that same plastic 15 quart drain/catch pan from Wallyworld for years. It catches all the oil without a problem, make sure vent is open during filling. If it's very windy, I add a slip on rubber hose to the fumoto valve nipple so it doesn't blow around. I then pour the oil into a used Detroit Diesel 5 gallon oil bucket with a lid. It has a pop up vent to make it easy to pour into a recycling station tank. Go by any large truck or marine service shop, most have plenty of new/empty 5 gallon oil buckets they will give you.
Old Oct 21, 2011 | 09:50 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Now that I have a fumoto, it will be easier now. I use milk jugs, the clear ones. The recycling collectors say they will only take the oil "in milk jugs". I can't send it to them in the oil cans.
Vancouver, Wa.
Old Oct 21, 2011 | 11:25 PM
rollerstud98's Avatar
rollerstud98
I use empty 5 gallon lacquer containers. Used to anyways.
Old Oct 22, 2011 | 12:04 AM
1957F100's Avatar
1957F100
I dont use any oil drain pan either. I have the fumoto valve with nipple. I always keep the empty oil jugs from my previous oil change. I then fill the jugs one by one till the engine is fully drained. I put the caps back on the jugs and drive to the local disposal place. That way I have no pan to clean up and I have to put the oil into the jugs anyways to dispose of it and I just think I would make a mess trying to drain the oil pan into jugs after I do the oil change.
Old Oct 22, 2011 | 10:53 AM
hardRESET's Avatar
hardRESET
Why yes, it is that big..
Thumbs up And the winner is...
All great ideas guys, and I am glad that posted here. I had ordered one of the Fumoto valves when I saw that someone had one on their signature. I wasn't real sure of all the uses but the one that did stand out was the fact that I would only need a wrench once. I had not even thought about the fact that I wouldn't need a pan if I attach a hose to it.
So I am going with the milk jugs on this run, I asked my girlfriend to save me about five of them which shouldn't take but a week with her two teenage sons... . Then the next time I should have the gallon jugs from the change of oil this time.
Shouldn't have to get anything real fancy on the hose should I and just from a place like Advance Auto Parts for it?
Old Oct 22, 2011 | 10:55 AM
1957F100's Avatar
1957F100
Nope just get a regular rubber hose that fits snugly on the nipple of the fumoto valve
Old Oct 22, 2011 | 09:34 PM
zhilton's Avatar
zhilton
Originally Posted by hardRESET
...geez, what a bonehead...
Nah, just a brain fart. We all have 'em from time to time.
Originally Posted by texastech_diesel
The front should be high enough. I can fit under there no problems; without a creeper I can get under the front axle, but now with to the valve I can reach around the axle to put on the hose, so a creeper works to get me close enough. Coming in from the front is easier I think, no running board to get whacked with.
Exctly, there's lots of room under a stock height truck. The lift guys just have a little more room. And I second the idea of coming in from the front/under the bumper to get to the drain plug. The only time I slide under the running boards is when I'm headed to the HFCM to swap out primary fuel filters.
Old Oct 23, 2011 | 06:58 PM
t4m4m4's Avatar
t4m4m4
Originally Posted by dchamberlain
If it's not, get a set of Rhino ramps. I use them for the car, cause I have to. And sometimes for the truck to get a little extra room.
Amazon.com: Blitz Rhino Ramp 8000: Automotive
I use them whenever I don't feel like putting my car on jack stands. The rubber feet fell off quickly, but they didn't make much of an improvement on traction anyway, so no real problem. Very durable. I'm pleased.
martin123456789
Jul 26, 2010 06:54 PM
bulletpruf
34
Apr 1, 2010 08:30 AM
turbo_06
Dec 12, 2006 07:43 PM
michaelbrainardatwor
33
Oct 14, 2004 09:19 PM
fightercowboy
1997 - 2003 F150
20
Aug 26, 2004 12:39 AM
