right trans fluid
Old Oct 21, 2011 | 05:32 AM
deerbuster's Avatar
deerbuster
right trans fluid
what fluid does a cruisematic take. ive been told its the old type F fluid, but the trans part number starts wit an E8 number,did the make them in the 80s? if so wouldn't it take dextron 2?
Old Oct 21, 2011 | 11:30 AM
jowilker's Avatar
jowilker
The Cruse-O-Matic calls for Type F, There is a new product like the one you referred to that can be used in place of. I believe it is Dextron II but verify. I still look for Type F.
John
Old Oct 24, 2011 | 12:40 PM
MIKES 68 F100's Avatar
MIKES 68 F100
on same subject anyone know how many quarts of fluid a c6 takes ? not draining converter just replacing leaking pan gasket and filter .
thanks
Old Oct 24, 2011 | 01:52 PM
DavidB's Avatar
DavidB
Depends
on what transmission you have. All of the older automatic transmissions from Ford use Type F. I believe that Ford changed to Mercon/Dexron about 1976. Check the dipstick. If it is original, it should be marked with the fluid type. If you can post the transmission tag number, not the casting number from the case, we can nail it down for you.
turbill
Dec 18, 2010 04:31 PM
Crone
Nov 4, 2009 08:10 AM
65f100_352
Oct 8, 2007 01:54 PM
Stoogefan
Jan 23, 2007 08:52 PM
banjopicker66
Jul 18, 2004 01:02 PM
