2005 f350
Old Oct 20, 2011 | 11:49 PM
baller's Avatar
baller
2005 f350
found out my ipr was the problem. once truck is started every vital sign looks good duty cycle is 23% and idles hot between 500 and 600psi and goes over 2000 when you give it gas at an idle. if you shut the truck off and start it imediately back up when it's hot it fires right up but if you let it sit for 15 or 20 min it's an extremely long start up, but once again when it fires up all numbers look good. icp sensor for the long start up only shows like 360psi but eventually starts. is it possible i have stuff in the ipr i just installed? when i first installed the new ipr it ran like a champ and was having no problems it seemed
im stumped and seriously tired of reading and just want this thing to run properly. throws no codes
i appreciate all the feedback yall are very helpful and im glad to be apart of this site.
Old Oct 21, 2011 | 11:18 AM
baller's Avatar
baller
anyone?.....
Old Oct 21, 2011 | 11:26 AM
2006powerstroke90's Avatar
2006powerstroke90
No problems starting cold....
Problems starting hot.....
2005 6.0.....
STC fitting is my best bet.
Old Oct 21, 2011 | 12:46 PM
NewToDiesels's Avatar
NewToDiesels
2005 6.0.....
+1
Sorry to say, your IPR valve was part of the problem. The rest lies under your HPOP cover more than likely.
Old Oct 21, 2011 | 01:49 PM
NewToDiesels
How fast does it start when cold? What does your IPR % and ICP PSI read when cold?
Old Oct 21, 2011 | 02:33 PM
BLADE35's Avatar
BLADE35
sounds like HPO bleeds off if it sits a bit gotta have a small leak somwhere
Old Oct 21, 2011 | 03:12 PM
NewToDiesels
That's exactly what I was thinking.
Old Oct 21, 2011 | 04:19 PM
egregg57's Avatar
egregg57
I have a 2005 F-350 as well. @ 81K miles I started having the same issue. A pressure check identified the problem as the STC fitting on the HPOP. With labor and new part(s) it cost me $899.99. I wish repairs in shops were not in factors of $1000.00 a pop....ugh! $899.99 isn't 1K but they cut me a break because the shop (not a Ford Dealer) was having difficulty finding the problem. They cut me a break on some labor time. It was going to be about $950.00.
After doing some research here and making a recommendation to them about the pressure check, they found it. Ford shows 7+ hours labor required.
Eric
Old Oct 21, 2011 | 04:25 PM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift
DAMN !!!!!
What's their labor rate. The SCT fitting kit only cost about 60$. They charged u 850$ labor.
OMG !!!!! I'm glad I do my own work on my truck. No way I could or would pay that kinda money.
Old Oct 21, 2011 | 04:41 PM
egregg57's Avatar
egregg57
Originally Posted by 05 f250 6 inch lift
DAMN !!!!!
Well, the kit cost a bit more than that. It wasn't a Ford dealer that did the repair, but the gaarage had to get the part from Ford and Ford wasn't nice about the price they had them for.
I probably coud have done the work myself but I was leaving for Acadia National park in a day and a half. There was no way I was going to be able to get in there and do it myself in that amount of time.
The shop did a good job and took care of a couple of other small issues as well. I would have liked to have paid less but the work is guarranteed, this shop does a lot of work for me and I trust them. They haven't let me down yet.
Eric
Old Oct 21, 2011 | 07:16 PM
cheezit's Avatar
cheezit
$850 labor is a fair price trust me.
Old Oct 21, 2011 | 10:45 PM
egregg57's Avatar
egregg57
I trust you cheezit! I was told it would have been more if they needed to pull the cab. But lucky for me, Brandon my mechanic weighs about 115 in winter clothes. He didn't have a bad time of it he tells me!
Old Oct 22, 2011 | 12:43 AM
cheezit's Avatar
cheezit
naw no need to pull the cab. just have to remove the turbo.
Old Oct 22, 2011 | 09:33 AM
npccpartsman's Avatar
npccpartsman
I totally agree that 850 is a fair price for an STC fitting change. It's pretty labor intensive and a lot of stuff to remove and replace. I know a dealership usually charges about twice that.
Old Oct 24, 2011 | 02:36 PM
baller's Avatar
baller
sorry guys ive been out of town. im pulling the pump as we speak and im down to the egr cooler. how do i remove or move it out of the way
