steering wheel swap
Old Oct 20, 2011 | 09:16 PM
collinft's Avatar
collinft
steering wheel swap
can i mount my 78 f150 steering wheel with floor shift on my 77 f100 auto?i need the stock one back on for a safety inspection
Old Oct 20, 2011 | 09:20 PM
thekingofcows's Avatar
thekingofcows
Yes you can.
Old Oct 20, 2011 | 09:41 PM
collinft's Avatar
collinft
thank you sir
Old Oct 20, 2011 | 09:48 PM
collinft's Avatar
collinft
i also just got all new tie rod ends and drag link and a wheel alignment and now the wheel is way off.whats the best way to center the wheel again?do i just put the wheels straight and and install the steering wheel straight again? or did the shop not install everything correct?
Old Oct 20, 2011 | 10:16 PM
thekingofcows
Count the turns lock to lock and divide that number in half, turn the wheel to it stops and then turn it back the calculated number of turns and install wheel straight. This will only work if you tierods and trac bushing are in good shape.
Old Oct 21, 2011 | 08:04 PM
hasteranger's Avatar
hasteranger
take it back to the alignment shop and point out that they didn't line up the wheel. They did that with my mom's toyota, lined it up and the steering wheel was way off. I took it back for her and they fixed it right away. Means the guys got lazy and adjusted the tie rods under the truck without paying attention to which way the wheel was pointing. It happens.
Pdaw1541
May 16, 2018 12:36 AM
jonrjen
6.7L Power Stroke Diesel
Feb 20, 2015 07:26 PM
78Ranger400
Nov 20, 2010 09:22 PM
dog150
Dec 14, 2007 04:15 PM
seumas
Sep 25, 2004 08:38 PM
