Does anybody know if it is possible to disconnect the lights from being on all the time the truck is running to just coming on with the switch inside the cab? I've heard there is a module that needs to be unplugged but I can't figure out where it is and If anybody has any pictures of it, that would be great. Thanks.
James, there is a small cage right behind the drivers headlight. Just disconnect the wire going into the switch behind that cage
Ken, I believe I see the cage... Does it have a few hard lines going into it on the top? I see a wire going into the back of it near the battery. Is this the one you are talking about?
Thanks for the picture. I found it... I don't have foglights on the truck, but I want to add some...
If you add fog lghts you will need to add a relay and if you fuse it separate then removing the DRL resistor/fog light relay fuse is the best and easiest way to disable the DRLs.
