SGII Issue
Old Oct 20, 2011 | 04:30 AM
JonArmy's Avatar
JonArmy
SGII Issue
Using my SGII I have it show fWT, EOT, FSS, and BSTm The problem I keep having is at times the XGuages aren't working, I check the settings and everything is correct but they don't show anything. Could there be a problem with my SGII. Most times everything is fine, but once in awhile they don't show anything.
Old Oct 20, 2011 | 04:34 AM
JonArmy's Avatar
JonArmy
My SGII is version 3.17, the pre-programed guauges read fine its just the XGuages that don't read
Old Oct 20, 2011 | 04:43 AM
npccpartsman's Avatar
npccpartsman
Are you turning it on before you start the truck?
Old Oct 20, 2011 | 04:53 AM
JonArmy's Avatar
JonArmy
No tunning, all stock, at times I just clean the connector and it works fine
Old Oct 20, 2011 | 04:54 AM
JonArmy's Avatar
JonArmy
I have it on and running and it acts up
Old Oct 20, 2011 | 04:58 AM
npccpartsman
I've always had the same issues. At times I have to turn the truck off, let the SGII go to sleep, restart the truck and let the SG come back on by itself. It also happens if I unplug the SGII while the truck is running. I can't tell you what it is but mine does the same thing.
Old Oct 20, 2011 | 07:11 AM
jimmyv13's Avatar
jimmyv13
Mine does the same thing 2 or 3 times a week. Kinda of annoying, but it always comes back alive when I turn the truck off for a bit and then back on.
Old Oct 21, 2011 | 09:27 AM
jdadamsjr's Avatar
jdadamsjr
on a pretty regular basis I will notice the sg is not displaying....
since I have it mounted right in front of the gear display on the dash, I just loosen the plug and reinsert and it always boots up then... (DO THIS WHEN AT RED LITE !)
Old Oct 21, 2011 | 10:20 AM
SixGunCaliforniaKid's Avatar
SixGunCaliforniaKid
Check the go to sleep settings in the menu scince I changed mine to RPMS the only problem Iv had is it not automatically turning on when I start the truck... for some reason I think Iv noticed it messes up when I plug or unplug stuff into the cig lighter adapter (not the upper one the lower one) its ran off the same fuse as the OBDII reader...
just a thought is your cell phone pluged in and charging?
Old Oct 21, 2011 | 10:25 AM
jdadamsjr's Avatar
jdadamsjr
jesse - u may be on to something there !
never associated it with the plug cycles of the gps and various chargers and tablets, etc....
isn't really a bother to get it going again so haven't looked into it at all
Old Oct 21, 2011 | 03:00 PM
SixGunCaliforniaKid
Everyonce in a while my lil hamster on the wheel gets pegged with a carrot and starts runnin again LMAO This was one of those moments....
Old Oct 21, 2011 | 06:43 PM
jimmyv13's Avatar
jimmyv13
I have my GPS and phone charger plugged in all the time.
Old Oct 21, 2011 | 07:53 PM
JonArmy's Avatar
JonArmy
I keep the GPS pluged up, a few hours after the problem, I let the truck sit and the SGII go to sleep, then do a KOEO, the SGII didn't automatically turn on, so I powered it on and the xguages worked, and since then it has been working fine.
Steve Girardin
1978 - 1996 Big Bronco
Jan 8, 2016 08:00 PM
dwrestle
Sep 3, 2006 07:38 PM
