Sponsored by: Real Truck
Replacing shocks & adding springs
Old Oct 19, 2011 | 09:19 PM
LIKENIT's Avatar
LIKENIT
How do I know whether it is time to replace shocks or if I should add overload springs.
I have a 99 F-350 with 130, 000 miles 4x2 that I tow a 5th wheel with. I'm right about the 10,000 lb GVWR for the truck when loaded and have weighed a few different times on Cat Scales. If I hit a bad piece of pavement or hole I get a banging sound like it bottoms out. I don't know if that is normal or something I should address.
Old Oct 19, 2011 | 10:40 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
To test your shocks go the to back of your truck, climb on the bumper and jump up and down. Then STOP! Look at you, you look like a fool.
Just kidding, pay attention to how quickly the truck stops bouncing. Good shocks will stop bouncing in 1-2 bounces. Ok shocks 2-3. 3+ means its time to replace.
Old Oct 20, 2011 | 07:46 PM
Nice Work Truck's Avatar
Nice Work Truck
Have you thought about some air bags?
Old Oct 20, 2011 | 08:06 PM
PA-Mark's Avatar
PA-Mark
Check the bump stops to see if you are bottoming out. Also Just a FYI if you need overload springs, I have a set outback that you can have... They are the ones from supersprings. You just got to come and get em. Anyways, If you are at or neer your load limit, and tow regularly, then you should deff get something.
Old Oct 21, 2011 | 07:42 PM
LIKENIT's Avatar
LIKENIT
Thanks for the offer. I'm from Duluth, MN, in Louisville now and heading for the SW for the Winter.
I am going to do some checking around to see what I can find. Thanks for the help.
Old Oct 21, 2011 | 08:33 PM
redford's Avatar
redford
FTE Leadership Emeritus
Sounds like a textbook application for air bags.
treverd
Nov 12, 2016 12:41 PM
turboboost
Aug 31, 2009 11:20 PM
DOUBLEF222
Mar 2, 2008 08:36 PM
mstaser
Jan 31, 2006 11:49 AM
fordrulesx
Jun 30, 2003 10:46 PM
