Cab Swaps
Old Oct 18, 2011 | 08:15 PM
Boba Fett's Avatar
Boba Fett
Cab Swaps
I wanted to ask if anybody knows if you can swap a cab from an 80s or 90s Ford Truck onto a 77 F-250 frame? I know it will look different, but will the bolt holes line up.
I also wanted to ask the same about the beds. I assume they are because I see 70s trucks with later beds.... but we all know what happens when you assume!
Old Oct 19, 2011 | 05:50 AM
Poison Oil Racing's Avatar
Poison Oil Racing
If you can weld and fabricate, then Yes it will fit. Hell, i could put a Nash body on my '76 if I wanted too, just a bit more welding and fabrication that I feel like doing
Same goes with the bed. I am putting a '58 bed on my '76. Just had to fab up a couple of brackets and drill some bed holes.
Bottom line, you will have to measure and measure again to see what will fit and what you will have to fabricate. I doubt, but could be wrong, that it will be a direct replacement bolt-on.
Old Oct 20, 2011 | 04:56 PM
ChaseTruck754's Avatar
ChaseTruck754
Unless the '77 is an early '77 and a 4wd the beds will be VERY close. I have read here that they are a direct swap, but when I put an '87 bed on my '74, 2wd frame the holes weren't exact. They were within a 1/2" or so - but far enough off it will take drilling to get the bolts in.
ollirrap
Nov 15, 2015 04:37 PM
sam_stach
Oct 17, 2015 10:30 PM
jtapal
Mar 8, 2011 10:01 AM
smaynor
Mar 5, 2003 05:39 PM
Blaine
Mar 28, 2002 01:40 AM
