WIF sensor & indicator operation questions
Old Oct 18, 2011 | 02:12 PM
honeydew's Avatar
honeydew
This morning for the first time since I've owned this truck the "water in fuel" indicator illuminated during the key-on glow plug phase along with the other lights which temporarily illuminate. The WIF light goes out when I start the engine. This has happened during all subsequent starts throughout the day. A few days ago I drained the baldwin filter on the frame rail and found a small amount of water. Drained the bowl earlier today but had to use a catch pan at work so could not check for water. WIF light behavior continued to occur after bowl draining.
So my questions are:
1. Does the WIF illuminating briefly and going out when engine starts indicate a WIF condition?
2. If not, why did the indicator just start illuminating today?
Thanks in advance.
Old Oct 18, 2011 | 05:46 PM
honeydew's Avatar
honeydew
C'mon guys, help me out a bit here please. I've never seen the "water in fuel" light illuminated before today. Now it comes on for a couple seconds and goes out before engine is started.
Does anyone else see this light along with the other briefly illuminated lights when they turn the key on?
Old Oct 18, 2011 | 06:13 PM
BigAlsPSD's Avatar
BigAlsPSD
I would think it would be normal to come on during the illumination test, although I can not at this time say with 100% certainty that that is true. Have you tried opening the drain and seeing if it illuminates after draining the supposed water?
Old Oct 18, 2011 | 06:21 PM
honeydew's Avatar
honeydew
Yeah I drained the fuel bowl today and the light is still coming on during illumination test but was not ever before today.
Old Oct 18, 2011 | 06:27 PM
BigAlsPSD's Avatar
BigAlsPSD
If I'm correct and it is part of the illumination test, it is possible that your bulb behind the light was "flaky" and may have reattached it's filament. I will go out and see if my WIF light comes on.
Old Oct 18, 2011 | 06:28 PM
PaysonPSD's Avatar
PaysonPSD
Just checked. My WIF lamp comes on and goes out in about 2 seconds with KOEO. Like Alan said it is a normal lamp test.
Old Oct 18, 2011 | 06:34 PM
dothedew192's Avatar
dothedew192
Yes? Every light on my dash comes on when I turn the key on, including the water in fuel light. Strange that yours never came on before?
Old Oct 18, 2011 | 06:35 PM
BigAlsPSD's Avatar
BigAlsPSD
I checked and see that others did as well, yep, comes on during normal lamp test. You might have an issue with the bulb or possibly a poor connection for the fuel bowl heater/WIF plug.
Old Oct 18, 2011 | 06:37 PM
honeydew's Avatar
honeydew
Great, thank you very much for checking. It is curious that it never has illuminated before but maybe it took an actual WIF event to wake it up...
My WTS light works fine except when outside temps are below 55F, then it doesn't illuminate at all even though GPs are running. Maybe the squirrely behavior is related.
Anyway it's a non-issue now that I know it is part of the normal lamp test. Thanks.
Old Oct 18, 2011 | 06:53 PM
BigAlsPSD's Avatar
BigAlsPSD
Originally Posted by FordUnEnthusiasts
holy crap!!!!!!!!!
What are you up to now? 16 posts all across the boards saying the same thing?
Old Oct 18, 2011 | 07:14 PM
PaysonPSD's Avatar
PaysonPSD
Check his username FordUNEnthsiasts.
The post disappeared so it's either a moderator having fun or a hacker,
but here's the LINK to all the holy crap posts.
He's starting to remove those as well because when I saved the link there were 17 now there are only 9.
Edit : Now they're all gone.
joshofalltrades
Mar 21, 2012 02:41 AM
3wildboys
Sep 15, 2011 10:13 PM
msavoy
18
Jul 1, 2009 06:02 AM
TxFordGuy
Jul 9, 2008 10:28 PM
TopThis8899
Jun 19, 2008 02:30 PM
