Transmission Fluid
Old Oct 18, 2011 | 12:31 PM
coyoteguard's Avatar
coyoteguard
Transmission Fluid
I have a 68 F100 with the 4 speed tranny, and I need to replace the fluid, any recommendations?
thank you
Old Oct 18, 2011 | 04:19 PM
jowilker's Avatar
jowilker
Regular ol 90WT should work just fine, don't know if you are in a cold winter climate where a multi grade might be used.
John
Old Oct 20, 2011 | 05:33 PM
60F100's Avatar
60F100
The original owners manual that came with my 68 F100 says to use Engine oil SAE 50 above 10 deg F and engine oil SAE 30 below 10 Deg F.
90 wt gear oil will work and is good if you have a noisy transmission, but 50 wt is all that is required.
Old Oct 20, 2011 | 07:04 PM
coyoteguard
Thank you for help
dbyrd342
May 20, 2016 11:20 AM
trvaughn
Jan 31, 2007 09:47 AM
fusioncom
Sep 11, 2006 03:28 PM
Enzo500
Aug 26, 2006 11:21 AM
