Body swap
Old Oct 17, 2011 | 08:48 PM
c_garsee's Avatar
c_garsee
Body swap
I have an 81 F250 with a good frame and eveything else but needs a new cab. I foubd a cab but it is an F150 will this work?
Old Oct 17, 2011 | 08:56 PM
4x484150's Avatar
4x484150
Yes. What year is the donor cab? If its an 80-96, cabs will bolt to the frame. 87+ cabs are more work to fit together.
Old Oct 17, 2011 | 09:16 PM
c_garsee's Avatar
c_garsee
Question
myne is a single cab so any single cab that is grom 80-86 nomatter a f350 250 or 150 will work?
Old Oct 17, 2011 | 10:48 PM
4x484150's Avatar
4x484150
Correct. They all used the same cab, regardless of what weight the truck was rated for. One thing you will need to pay attention to is the VIN tag on the cab. If you are putting a 1/2 ton cab on a 3/4 ton truck. I'm not sure if you can stick the 250 tag on the donor cab.
Old Oct 17, 2011 | 10:53 PM
ctubutis's Avatar
ctubutis
Yes, the titling might be a problem (ask your local DMV what the process is) but the bodies are the same.
Dieselborg
Jan 17, 2018 09:50 AM
ericconn
Oct 18, 2013 09:47 PM
Pitcher
Sep 27, 2012 02:08 PM
joncaudill
Jan 31, 2004 05:47 PM
bigricker
Apr 3, 2002 02:56 PM
